Odd CD changer behavior
Old Oct 14, 2008 | 12:53 AM
wombats777's Avatar
wombats777
St. Jude Donor '14-'15-17-'18-'19, '21,'24-'25-'26
Default Odd CD changer behavior
I have the 6 CD changer. When it finishes playing a CD (say slot #1), it switches to the next CD (slot 2) in the changer - as it should. After I while I shut off the car. Later, I get back in the car and start it up. Instead of finishing the new CD (slot 2), it goes back and restarts the previous one (slot 1). I have noticed that this has happened a couple times. Nothing worth going to the dealer about, just odd and a little annoying. Does this happen to anyone else?
Old Oct 14, 2008 | 07:15 AM
07MontyRed's Avatar
07MontyRed
St. Jude Donor '07 thru '26
NCM Lifetime Member
Do have the RDM (random) feature selected ...???
Otherwise, no it should not behave that way.
Old Oct 14, 2008 | 08:10 AM
Bill Baird's Avatar
Bill Baird
Yes, I've had that happen a couple of times. I've yet to figure out if the CD is being odd and doing that, or if I'm doing something to cause that. I don't think that I'm doing anything, but I'm still trying to figure it out. As a note, I do not have it set to "random".
Old Oct 14, 2008 | 08:27 AM
*FAÇADE*'s Avatar
*FAÇADE*
PHOTOSHOP SPECIALIST
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Since radio and CD settings are updated and saved for each driver (Personalization Settings),
using different fobs could cause the behavior that you described.
Old Oct 14, 2008 | 10:43 AM
wombats777's Avatar
wombats777
No. I don't have RDM selected. I've never used RDM.
I'm the only driver and I always use the same FOB.
Old Oct 14, 2008 | 11:52 AM
danl72's Avatar
danl72
That is odd. It is suppose to go back to where you left off.
To Odd CD changer behavior
