winter...NOOOO
Old Oct 15, 2008 | 01:26 AM
pinoyvette's Avatar
pinoyvette
Default winter...NOOOO
i hope i can stop it from coming but...i need to get a battery tender so i need an expert advice on this...whats the best product out there and where can you get them...im planning on storing it till the weather gets nice again...thx
Old Oct 15, 2008 | 01:27 AM
tpereira's Avatar
tpereira
I need one too
Ive been waiting to see a thread selling these things so I could pick one up
Old Oct 15, 2008 | 01:33 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Actually you don't need the best one out there, you just need a good one. I use three and they are all different and they all have worked the same for the last three years. Ranged in price from $25-$35.
Old Oct 15, 2008 | 01:39 AM
Racer's Avatar
St. Jude Donor '11
Here is one from a supporting Vendor, they claim it is the best, and I believe you said you wanted the best.
http://www.southerncarparts.com/corv...300-p-468.html
Old Oct 15, 2008 | 01:49 AM
Edshore007's Avatar
Edshore007
I use a CTEK Battery Charger US3300 and it works great. Does not over charge the battery.
Old Oct 15, 2008 | 07:46 AM
Jus Cruisin's Avatar
Jus Cruisin
Another reason why I ditched Michigan for Florida 15 years ago. The dry season is about here and the car events are getting started back up.
Old Oct 15, 2008 | 07:49 AM
SvetteC6's Avatar
SvetteC6
Old Oct 15, 2008 | 07:56 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I went to Advance Auto and got a Schumacher for about $20. A friend modified it so it plugged into my lighter. Used to loop the cord thru 1" top of window. Just recently found out from CF members that there's a little dimple on doorsill and can string cord thru it. Will do that this winter. Worked flawlessly all last winter for me.
Old Oct 15, 2008 | 08:07 AM
ATC399's Avatar
ATC399
The dimple works. Sears charger/tender...I think I spent about $30-$40...
Old Oct 15, 2008 | 08:24 AM
StanNH's Avatar
StanNH
I used a CTEK 3300 all last winter. In an unheated garage, with low temperatures frequently in the sub zero range, the CTEK kept the battery fresh for the entire winter season.
I suggest the cigarette lighter adapter for a very easy connect and disconnect.
Old Oct 15, 2008 | 09:51 AM
RED2008Z06's Avatar
RED2008Z06
Craftsman works for me....
Old Oct 15, 2008 | 09:57 AM
C6FirstVette's Avatar
C6FirstVette
Another for >>>
Michael
Old Oct 15, 2008 | 11:07 AM
Edify's Avatar
Edify
Just now starting to get bearable at night!
-Ed
Old Oct 15, 2008 | 11:10 AM
rjwoerheide's Avatar
rjwoerheide
Deltran Battery Tender Plus is what I have--not too expensive and doesn't over-charge the battery. Purchase the extra length cord.
Works great. I wouldn't winter without it
linky: http://www.amazon.com/Deltran-SuperS.../dp/B00068XCQU
Old Oct 15, 2008 | 12:53 PM
pinoyvette's Avatar
pinoyvette
what the difference between battery charger and battery tender?
they say to use battery tender for winter but the cytek3300 that most guys are using is a battery charger...can i get a clarification on this PLZ...thx
Old Oct 15, 2008 | 01:02 PM
SB60's Avatar
SB60
Been using a BT since my first Vette. I highly suggest using one!
http://batterytender.com/product_info.php?products_id=2
Old Oct 15, 2008 | 02:24 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I spent to much I bought mine from the Corvette Museum and it has worked flawlessly on my boosted C5
To winter...NOOOO
Old Oct 15, 2008 | 02:27 PM
SteveJ's Avatar
SteveJ
I was just going to disconnect the battery and hook it back up when spring arrives. Anything wrong with this strategy? I have the car in a garage with power available, if the battery tender is a better way to go.
Old Oct 15, 2008 | 02:28 PM
rjwoerheide
I think they might be saying "battery charger" but meaning "tender." You want to be sure that whatever you buy has a trickle feature so that when the battery is re-charged to full capacity, the tender "trickles" the power. Most good battery tenders will do this, but MAKE SURE! You will ruin your battery if your charger/tender over charges the battery.
I researched the heck out of this a couple months ago and I settled on the Deltran Battery Tender (as mentioned in my earlier response).
Old Oct 15, 2008 | 02:29 PM
rjwoerheide
Battery tender is a MUCH better way to go. Spend the $40.
