Electrical Problem Need Some Help Please!!!
Old Oct 15, 2008 | 05:23 PM
TMRoc's Avatar
TMRoc
Default Electrical Problem Need Some Help Please!!!
Just when out to my 2005 C6 corvette to change a CD and seen the dome lights on. I haven’t been in the car for three days. It it started right away no problems, but, when I shut it off and walked away the dome lights stayed on. Rechecked them to make sure I did not turn them on by mistake and they were both turn off. However the lights are still staying on. Restarted the car and shut it off again same thing (Imagine that, it didn’t fix itself). Now the green light (start button) is on and does not shut off along with the dome lights. I pulled out the dome lights so it would not being pulling any electrical power from the battery but I don’t know what to do about the start button and more important I have no idea what is causing this. Any help on this would be greatly appreciated.
Old Oct 15, 2008 | 05:28 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
By dome lights do you mean the lights under the mirror? If so, check the push buttons on the bottom of the mirror. It sounds like you have the lights(s) in the on position.
Tom
Old Oct 15, 2008 | 05:29 PM
THE BUD MAN's Avatar
THE BUD MAN
St. Jude Donor '12
push in the round button by your left leg....the one that dims the dash lights. You probably hit it by mistake..... I do it all the time
Old Oct 15, 2008 | 05:39 PM
Red Cell's Avatar
Red Cell
I'll bet this is the problem...
(After pushing there may be a turn involved...can't remember)
Red Cell.
Old Oct 15, 2008 | 05:41 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Get in car. Close door. Find this button, it will be easy to spot as the lights are on. Press it. Should be problem solved.
Old Oct 15, 2008 | 06:01 PM
TMRoc's Avatar
TMRoc
Default Thanks
I FEEL SO F*****g SUPITD right now.. the little button work just like it's suppose to. Thanks again.....
Old Oct 15, 2008 | 06:43 PM
talon90's Avatar
talon90
NCM Ambassador
Seriously, don't. It literally vies for the number one issue on the forum. You are far from alone. Besides, you can't be stupid, you own a Corvette.
To Electrical Problem Need Some Help Please!!!
