tire rotation
Old Oct 20, 2008 | 09:20 PM
cee6's Avatar
cee6
Default tire rotation
I know you can't rotate front to back but is there any advange to rotate from one side to the other side.
Old Oct 20, 2008 | 09:36 PM
John B.'s Avatar
John B.
No No NO
Old Oct 20, 2008 | 09:39 PM
phileaglesfan's Avatar
phileaglesfan
It would also involve dismounting the tire and rebalancing if your car has directional tires on them. Personally, I'm happy with tire wear and the performance so no reason to risk screwing either up. I guess that is a good way to find out if your dealer is a crappy one though if they charge you for a rotation.
Old Oct 20, 2008 | 09:40 PM
jxhunte's Avatar
jxhunte
No front to back or side to side rotation. Just buy new tires when wear dictates.
Old Oct 20, 2008 | 09:42 PM
philip_g's Avatar
philip_g
or 500 miles, whichever comes first.
Old Oct 20, 2008 | 09:48 PM
ALS 08's Avatar
ALS 08
No point.
Many performance tires are directional so a simple do it yourself L-R wheel swap would make tire rotation backwards, not a good idea. Also TPMS would indicater would show wheel on wrong side. Unless you feel like dismounting & remounting the rubber between rims. Not.
Old Oct 20, 2008 | 09:50 PM
Vet's Avatar
Vet
Make sure to have your alignment checked and keep inflation proper... no need for any rotation. I have a set of Supercars with close to 15k on them, they're maybe half worn, and worn nice and even... and I often run quite spirited in the twisties. No rotation.
Poor alignment is the reason for much of the early tire demise you may hear about with these cars.... that and abuse (such as doing burnouts and other illegal and abusive stunts).
Old Oct 20, 2008 | 11:41 PM
cmonkey713's Avatar
cmonkey713
Proper inflation and aglinment, you should not have a problem. Too much time and money to swap sides every 5K miles or so.
Old Oct 20, 2008 | 11:47 PM
2005ArcticWhite's Avatar
2005ArcticWhite
St. Jude Donor '05 thru '11,'18,'20,'21,'24,'25, '26
Originally Posted by John B.
No No NO
Old Oct 20, 2008 | 11:56 PM
BigJoe's Avatar
BigJoe
I'm surprised that no one has pointed out that you have different sized wheels and tires front to back. Probably not good to put the big ones on the front, small in the back...
Old Oct 21, 2008 | 12:16 AM
LMB 4 ME's Avatar
LMB 4 ME
From: Boca Raton Inlet, Atlantic Ocean (Floridas east coast)
Originally Posted by ALS 08
No point.
Old Oct 21, 2008 | 12:22 AM
Hoonose's Avatar
Hoonose
Yes it can be done if your tires are non-directional like the original equipment Z-51 tires.
The R to L swaps will cause your DIC to read the 'wrong' side tire, but that is easy to remember.
Theoretically you could extend your tire mileage if they are wearing unevenly. I did this the first 3 years of my C6 ownership, but don't recommend it generally as it did little to extend my tires. I did note a very slight high speed wander the first time I did it, and the wander improved when I swapped them back.
To tire rotation
