Quick winter storage question..
Old Oct 22, 2008 | 12:45 PM
vettnut69's Avatar
vettnut69
Default Quick winter storage question..
Should I pull the fuse for the Mild to Wild system for winter storage??
Old Oct 22, 2008 | 12:55 PM
MooseMan123's Avatar
MooseMan123
Unless you wired it so there's no battery drain, then I'd say yes.
You may also want to buy a "Battery Tender" trickle charger to leave on while
shes in storage.
Old Oct 22, 2008 | 01:07 PM
vettnut69's Avatar
vettnut69
shes in storage.
No, I didn't wire it so there would be no battery drain so figured fuse had to be pulled but wanted some reassurance... Thanks!
Old Oct 22, 2008 | 01:23 PM
rjwoerheide's Avatar
rjwoerheide
I would also suggest getting a battery tender. I use Deltran's Battery Tender Plus. There have been lots of threads on here about battery tenders, if you are curious to search for them.
Old Oct 22, 2008 | 03:53 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
regardless of pulling fuse or not in a few weeks time u will ahve a dead battery, either unhook it or get a tender
To Quick winter storage question..
