Warning about jack pads
A little history first: I had a C5 for years that did not have pads installed. The vehicle had been to the same service dept many times and there was never any accidental damage to the rocker panels.
When I got my C6 about a year ago, I wanted to do be proactive and protect it by installing jack pads whenever it went in for service (at same service dept I always go to).
Well, the first couple times, no problems. However, the last time, the pads got caught on the lift and it ripped three of the four off, while chipping and cracking both rocker panels in the process! To the service depts' credit, they fessed-up to what happened before I picked-up the car and also offered to cover the damages. Of course, it would have been pretty difficult to try to slip that past me without noticing.
By the way, I always made it a point to tell the service writer that the pads were installed. I suppose maybe a note on the dash for the tech might have been more effective, but it's sort of a moot point now.
Anyway, my conclusion from this experience is that there is as much risk, if not more, of damaging the rocker panels from having jack pads installed, as there is from not having them installed. I know people have had damage without pads, but I went for years without pads and never had a problem.
I'm sure someone will ask what kind of pads I was using, and they were the rectangular BMW ones that many forum members use. I don't know, maybe they are too thick, but as a result of this experience I don't plan to reinstall any jack pads.
Anyone else have similar horror stories?
I've used them a couple more times for oil changes where I drop the car down onto jack stands at the puck locations.
I don't think that leaving them installed full time is such a good idea. Of course for the aluminum ones you can't anyway. They'd eventually fall off.
Just had my 08 in for oil change and was feeling a little uneasy about it (maybe due to the fact they had scratched/dented up my fiancée’s car and didn't fess up) so was standing outside the bays when a "newbie" jumped in the car and headed off to the hoist in the last bay..
STOP!!!!
No pucks.. don't use that lift, you need to use that one over there, the drive on lift! "What you mean no pucks, what’s a puck" came his response..
Sure glad I was standing outside!
I generally drive the car in position on a lift and then install the pucks. Don't think I would ever leave any type of pucks installed on the car since they would just be something else to drag on the street.
One of the mistakes I admittedly made is that when I first installed the pucks, I pushed the locking pins all the way in, which made it very difficult to get them off again. So, I just decided to leave them on and never had a problem bottoming-out or anything like that; that is, until this happened.
It sounds like many (some?) people have the benefit of watching (or even helping) their car get prepped for service in order to prevent these situations from happening. Unfortunately, my experience has always been that I drop the car off and they start working on it sometime later. Which, of course, means the car is at the mercy of whoever happens to be driving it in or out of the service bay.
Anyway, like I said, no more pucks for me. I never had any problems when I didn't have them, so I'll take my chances that way.
I've got a double set of the hockey pucks in my trunk storage compartment, another set at home in the garage, and gave a set to the Corvette tech at the dealership. He likes them.
I think there is more to the story than you are being told since they/you(?) were able to drive on the lift without problems. The mechanic probably did not lower the alignment lift completely and scraped the rocker panels and pucks as the car drove off the edge. Easy for them to blame it on the pucks instead of admitting a mistake.
