Dynamic Alignment Question
Old Oct 28, 2008 | 10:10 PM
MachAll 2005's Avatar
MachAll 2005
Default Dynamic Alignment Question
Looking at the geometry of the rear suspension, it looks like there will be more toe-in at weight is added....either from driver and passenger or dynamic compression of the spring.
- Is this a correct Toe-in observation?
- Also looks like Camber will be lost with loading of the
suspension...correct?
If I have it figured out, the front suspension should do the same.....
- Correct?
- Toe-in?
- Camber?
Thanks in advance for your knowledgeable response.
Old Oct 28, 2008 | 10:38 PM
Shortimer's Avatar
Shortimer
This one is beyond me but I'll watch for an answer.
Old Oct 28, 2008 | 10:46 PM
mikeci's Avatar
mikeci
- Correct?
- Toe-in?
- Camber?
I think the only thing that changes w/ the loading and unloading of the suspension, front or rear is the camber. the toe in and caster do not change unless you hit something or make an ajustment to them.
Mike
Old Oct 28, 2008 | 10:49 PM
Jahan's Avatar
Jahan
I have data from an 05 C6 that shows how the following settings change with jounce, assuming you start from curb height:
Rear toe: IN
Rear Camber: More negative
Front toe: OUT
Front Camber: More negative
This is only data from one car though, so YMMV. Are you looking at a drawing or photo, or your own car? If you send me the picture, maybe I can provide some insight.
Old Oct 28, 2008 | 10:50 PM
Jahan's Avatar
Jahan
Mike
Not true. Everything changes with everything.
Old Oct 28, 2008 | 10:59 PM
Modshack's Avatar
Modshack
Most independently suspended cars go through changes as the suspension loads and unloads. All cars and geometries are somewhat different but as a general rule, as rear suspension compresses the wheels camber in and toe in. The geometry responsible for this is based on the relationship of the locating arms, length of those arms, pivot point placement, bushing stiffness/compliance and design, etc. The Corvette uses a relativly conventional double A arm arrangement to arrive at the desired motions. Changes in alignment aid in handling for one, stabilize the car under cornering loads and suspension loading/unloading. On the front the change is generally less, both Toe and camber, but still changes nonetheless....The suspension engineers have worked this all out..Some manufacturers use very exotic combinations to achieve the desired changes based on their engineering design.
You'll find some interesting information here:
http://www.carbibles.com/suspension_bible.html
Old Oct 29, 2008 | 08:19 AM
mikeci's Avatar
mikeci
after reading some other articles on suspension http://www.ozebiz.com.au/racetech/theory/align.html
they seem to talk more of deflection of the bushings that causes the toe change. all things being equal the harder the bushing the less toe change. never the the less I stand corrected
Mike
Old Oct 29, 2008 | 08:38 AM
BlackZ51Vett's Avatar
BlackZ51Vett
I use this:
http://www.pfadtracing.com/docs/camb...t-settings.pdf
Old Oct 29, 2008 | 09:46 AM
Modshack's Avatar
Modshack
Mike
Bushings are one of the factors involved in the design along with geometric changes... As an example, when the Audi TT came out in '99 there were a few well publicized high speed crashes in Germany. It was determined the car and it's suspension were a little too "Direct". The front bushings and a few other parts were re-designed to basically dumb down the suspension for the average guy. In the pic below you can see the early front control arm and bushing on the left, and the redesign on the right. Note the aluminum inserts in the bushing design to control movement and compliance in certain directions..This is a good example of what you commented on and what they mention in the link you posted. .
Old Oct 29, 2008 | 10:32 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Steve, I thought the early TT crashes in Germany were due to rear end lift? And that the resultant change was to add that spoiler on the rear of the cars, no? A bit more explanation plz.
Old Oct 29, 2008 | 10:38 AM
Fastcar's Avatar
Fastcar
Originally Posted by BlackZ51Vett
What vette are these spec used on? C5 or C6?
mikeci's Avatar
mikeci
Hey Steve,
leaving deflection aside. why would the toe change as the suspension loads and unloads? the only movement of the a-arms is up and down right? that's if the points of contact of the wheel hub assembly to the a-arms are perpendicular to the ground. to change the toe the a-arms would have move laterally or the tie-rods would have to compress or expand. right?
Mike
Old Oct 29, 2008 | 10:43 AM
Modshack's Avatar
Modshack
Hi Bill..It was a combination of several things (including lift). In addition to adding the Spoiler, they changed the sway bar rates, front shocks, and front lower control arms as shown above. Most early cars were recalled and had this kit installed in late 2000, early 2001 along with the option to add Electronic Stability control.. It is rare to find an unmolested early example now and they are fairly desirable among the TT enthusiasts.. I actually sell a bushing adapter that allows the late arms to be able to accept the early style bushing. Gets back some of the feel they dialed out...
Old Oct 29, 2008 | 10:47 AM
Modshack's Avatar
Modshack
Mike
Mike...A arms do not operate in a completely parallel world (Rear anyway). Notice the top is shorter than the bottom. That causes the wheel to move in an arc (up and down plane or camber). Subtle positioning of the pivot points allows a very slight amount of arc forward (in and out plane or toe) which causes the toe change..(Rear suspension)
On the front, what you describe is called bump steer. Geometry is designed so Toe change from the arms is kept to a minimum when articulating and is largely controlled by the bushing deflection as discussed. Bump steer is when Tie rods are not perfectly level from Rack to wheel and as the wheel moves up and down an arc is scribed from the end of the steering rack to the wheel..The subtle movement in and out of the wheel at the tie rod end, and consequent toe change is called bump steer. This is why lowering a car may result in some handling changes you did not anticipate....The closer that arc is scribed up and down from the parallel plane of the tie rods and the longer the rod, the less potential "steering" input from suspension articulation..
Old Oct 29, 2008 | 11:02 AM
mikeci's Avatar
mikeci
A arms do not operate in a completely parallel world. Notice the top is shorter than the bottom. That causes the wheel to move in an arc. Subtle positioning of the pivot points allows a very slight amount of arc forward which causes the toe change..
I thought the reason for unequal length a-arms was to allow the increase or decrease in camber as the suspension moves. I'm going to have to read up more on the subject before I jam my foot deeper into my mouth.
Old Oct 29, 2008 | 11:19 AM
Modshack's Avatar
Modshack
:. I'm going to have to read up more on the subject before I jam my foot deeper into my mouth.
Ha ha! No problem. Unequal A arms are just one of a dozen ways to do that. As long as you're in the learning mode, here's another excellent read which discusses and illustrates the stuff we've been talking about...
http://www.mgf.ultimatemg.com/group2...n/tracking.htm
Old Oct 29, 2008 | 11:37 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I always learn more from these threads with Steve posting than I thought I would...thanks, Steve!
To Dynamic Alignment Question
Old Oct 29, 2008 | 11:38 AM
Modshack's Avatar
Modshack
Hey, Thanks Bill!.....
Old Oct 29, 2008 | 12:05 PM
mikeci's Avatar
mikeci
yup,
Steve has always been a good source for me in the past when I did my suspension over. btw I went w/ the pfadt shocks instead of the bilsteins. I can't wait to pick his brain when I'm ready to do the engine over. thanks again Steve!
Old Oct 29, 2008 | 02:54 PM
Jahan's Avatar
Jahan
The location and angle of the tie rod also affects toe change . . . the difference between how the tie rod pivots and how the control arm pivots will cause the wheel to be pushed or pulled slightly in or out.
While it may not be obvious at first, these changes in toe or camber can be a good thing if the engineers design and tune them properly . . . they can help increase stability or make the car respond slower or faster, or change the oversteer/understeer balance.
Suspension geometry is a very complex thing. There are MANY attributes to consider, and they are all dependant on eachother. Roll center height and migration, anti dive, anti squat, camber and toe curves, how the alignment changes with cornering and braking loads . . . it's NOT as simple as most enthusaists think. These design attributes lay the foundation upon which the engineers tune the springs, shocks, steering, and tires. If the geometry isn't right, the rest of the car won't be very good either.
