Center cap o-ring
Old Oct 29, 2008 | 03:54 PM
Prodago's Avatar
Prodago
Default Center cap o-ring
I'm looking for the rubber o-ring that goes on the center cap of this wheel. I do not know the manufacturer. The groove that it fits in is 1/16th" wide and about the same depth and is 2-5/8" I.D. I've looked at hardware stores, discount tire.etc... anyone know where I can get one?
Old Oct 29, 2008 | 04:10 PM
AutoCutter's Avatar
AutoCutter
Pool/Spa stores that service pumps & stuff normally has larger sized 0-rings and should have something that will work. Lowe's has some really large ones and I would hunt through the plumbing supplies for an item that uses a large size o-ring. I take it the o-ring holds the center cap in place? If so you might just glue smaller sections of o-rings in the proper matching locations in the wheel center. Anyway good hunting and good luck.
Old Oct 29, 2008 | 04:18 PM
Prodago's Avatar
Prodago
Thanks and you are correct, the o-ring holds the center cap on
AintQik's Avatar
AintQik
They look like I forged. Call and ask for some of theirs. I have some in the garage somewhere and they sound about right.
To Center cap o-ring
