dimmer switch, how does yours operate
Old Oct 29, 2008 | 04:50 PM
HANNY's Avatar
HANNY
Default dimmer switch, how does yours operate
the dimmer switch on my 09 seems like its not working right (or i'm an idiot and dont know how to use it)
it will turn the inside lights on but doesnt dim anything, whether i push it pull it or hold my tounge just right.
Does anyone have a similiar year and how does yours operate? i would think it should at least dim the dash lights and radio maybe? thxs, paul
Old Oct 29, 2008 | 04:55 PM
jeffjob's Avatar
jeffjob
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
St. Jude Donor '13, '17-'18, '25
Hanny;
You need to turn and hold, it will then dim. I have forgotten at the moment if you need to push in, turn and hold, but holding the turn is the key.
Jeff
Old Oct 29, 2008 | 04:57 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Instrument Panel Brightness
The **** for this feature is located on the left
side of the instrument panel.
Push the **** in to turn on the interior lights.
Turn and hold the **** clockwise to brighten
the lights or counterclockwise to dim them.
During the day, this **** will adjust the instrument
panel brightness and at night will adjust all interior
lighting. Be sure not to have this **** turned all
the way down with the lamps on during the day.
Your Driver Information Center (DIC) may not be
visible.
Old Oct 29, 2008 | 05:01 PM
HANNY's Avatar
HANNY
Originally Posted by jeffjob
Hanny;
Jeff
thxs jeff, i tried to turn it and held it for like 30 seconds,,,,, i cant believe and new part would fail like that?
i did do the cags fuse thing maybe that effects it?
Old Oct 29, 2008 | 05:09 PM
Pocket Aces's Avatar
Pocket Aces
Are your head lights on? I think it may only adjust the dim if it thinks its dark outside.
Old Oct 29, 2008 | 08:32 PM
DSOMvette's Avatar
DSOMvette
St. Jude Donor '09
mine dims and yes the headlights Im pretty sure must be on, however it is pretty minimal the amount of dimming it does do, it does not dim to blackout as on most other cars
Old Oct 30, 2008 | 10:43 PM
K9KUZ's Avatar
K9KUZ
My 2005 is the same.
Old Oct 30, 2008 | 10:55 PM
RadarP3C's Avatar
RadarP3C
Very little adjustment...
Old Oct 30, 2008 | 11:02 PM
HANNY's Avatar
HANNY
I fingered it our fellas's thxs for the input. And your right there is little adjustment to it. ME
To dimmer switch, how does yours operate
