Tpms
Now that I have Nitto Invos tires (not runflats), I think they cannot be safely driven on at 20-22 psi. Is it possible to have the low pressure warning displayed at a higher reading, say about 25-26?
Thanks,
of course, you should check your pressure before each "drive off", and im sure you do. if a tire begins to go down, you should be able to sense it being that its not a run flat... esp. on the front... because of the tread width, it will start to pull.
Thanks,
The TPMS has a low pressure range of 24 psi and a high pressure range of 42 psi.
This range is not adjustable.
Tire pressure is not an absolute value. Tire pressure is a result of the size of the tire and the weight of the vehicle which results in a contact patch. This contact patch is supporting XX pounds per square inch of contact. The manufacturers recommendation for the vehicle with OEM size tires is 30 pounds per square inch (PSI.)
Tire pressure will also vary with temperature. If you are seeing cold tire pressures of 22-24 psi you need to add air to your tires, plain and simple. You will need to add more air as the temperature drops. Tire pressure is not a set it and forget it item. Tire pressure will vary approximately 1 psi for each 10 degree change in temperature.
pressure is also a result of heat.
the one thing i like about the direct style tpms is that if you notice a particular tire running higher pressure than the others when all are set at cold then it can give you an indication that you may have some "unhappy components" in that tire allowing for more flex and generating the heat. This is something that the tpms wont kick a warning light for, but if you check the pressures on the dic while running on a regular basis, especially if you think you might have a tire problem developing, it can send an early warning signal.
(at the drag strip, you can play with high pressure up front and low in the back..but set it to O.E. before you leave to drive home.)
