I love the bluetooth feature in my 09 and its been working PERFECTLY up until today. When receiving a call it will shut the music off and ring like normal, but when I answer it the music comes back on and nothing comes out of the speakers. The call is still active on my phone however and if I hit "transfer to phone" then I can carry out the call on my phone like normal..
If I make a call from my phone it will NORMALLY shut down the music and I can have the convo through the speakers/microphone. NOW I am just able to hear it through the phone and nothing out of the car speakers.
If I call someone by hitting the bluetooth button and say "call" then the call just gets transfered to my phone like I dialed from there.
It seems my speakers just wont work with the bluetooth anymore. If I use the bluetooth through the car I can not hear anything through the speakers and the person on the other end cant hear me through the microphone, I also can not use the phone normally during this time so I know the phone is still trying to use the "bluetooth" feature. At anytime I can press the "transfer to phone" button on my cell and it will work normally through the phone. I have tried re-pairing and nothing seems to work. I read the book and I can not figure this out. Has anyone else had this problem? Is it just me doing something wrong now? I want to figure this out before I take it back to the dealer.... THANKS!!
I have a verizon Dare. Its a new phone I dunno what traits the iphone has that are similar to the iphone. Do you guys have the problems from the get go or are they coming up later? also, once this behavior has started - will it go away if I pair a more compatible phone?....thinking about pairing my g/fs phone to see if it goes away...
Gabe
first thing i would do is reset your phone, take out the battery for a few minutes then try Pairing your phone again. Start from scratch and do a whole new pairing. if that dont work i would try a different phone and if still messed up you gotta issue warranty should cover. good luck ,pAuL
Yeah this has happened before. Just take the battery out of your phone and then repair your phone to the car. Make sure you delete the old pairing that you had in the car first.
This fixed the problem!
BTW if you have an LG Dare and you experience no feedback through the speakers then just delete your device from the car and re pair it after you have shut down the phone and taken the battery out... THANKS GUYS!
