Window molding problem
Old Nov 12, 2008 | 03:20 PM
JFFVETTE's Avatar
JFFVETTE
Default Window molding problem
Has anyone ever had a problem, with the window molding at the edge of the door panel and the bottom of the window rubbing, and folding down below the surface of the panel edge? This has happened twice now, and I don't know why. When it does, I can pull the molding out, and push it back into position, but there are marks where the molding was folded behind the panel edge.
I thought that maybe sometimes when the window indexes, it may be pulling on the molding enough to drag it below the panel edge slightly, and then when it goes back up it sticks below the surface.
Thanks for the help.
