need help
Old Nov 15, 2008 | 03:58 PM
billytruong's Avatar
billytruong
Default need help
i was driving to work today step on the clutch and a spring pop out
do any off you guy know what is come from do i have to fix it right away ,the car still drive fine here is the picture
Old Nov 15, 2008 | 04:00 PM
mksz51's Avatar
mksz51
That's the infamous clutch spring - some replace it and others drive without it.
Old Nov 15, 2008 | 04:58 PM
JohnRS's Avatar
JohnRS
I put a C5 spring in mine. I like the clutch feel much better than with the C6 spring. Spring costs less than $7 and only takes a few minutes to install.---John
Old Nov 15, 2008 | 07:12 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
That is the clutch return spring. It is o.k. to drive without it. It is there for a reason and it is stated that driving without it for a length of time it can cause pre-mature wear of the clutch. With that said there are owners on the forum that have removed (or not replaced) it when it broke and have driven with it off for two or more years without problems. Some (as noted) have replaced it with the C5 return spring as they liked the feel better.
Old Nov 15, 2008 | 07:15 PM
possessed's Avatar
possessed
Mine fell off a year ago. I threw it away and never looked back.
To need help
