Winter storage
Old Nov 19, 2008 | 06:59 AM
pmcvette's Avatar
pmcvette
Default Winter storage
I'm getting ready to store my car for the winter so I wanted to know if anyone has a list to follow so that the car is properly stored.
I was going to get a battery tender. What about gas treatment?
any ideas would be great.
thanks
Old Nov 19, 2008 | 08:07 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Check Anti Freeze
Add stabilizer to gas tank then filler up. Run the car to get stablizer into the fuel lines
Change oil? Filter?
Clean and Wax
I put in moisture gathering material in the car
Hook up to a Battery Tender not a charger
Blow tires up to 40#'
Put a piece of carpet under each tire so the tires are off the cement.
Place a cover over the car and your good to go.
Old Nov 19, 2008 | 08:10 AM
Sammgb's Avatar
Sammgb
Originally Posted by Red Rochester
Check Anti Freeze
Change oil? Filter?
Clean and Wax
I put in moisture gatherng material in the car
Except for the tire inflation step and the carpet under the tires, this is pretty much the same routine that I follow.
Old Nov 19, 2008 | 08:40 AM
rws.1's Avatar
rws.1
I do the above plus, I put a heavy duty plastic tarp on the garage floor to keep moisture away from the frame, instead of carpeting I put the car on 4 pieces of extruded sytrofoam ( pink) that I buy at home Depot.
It deforms from the weigh of the car an cradles the tires, spreading the load and eliminating flat spots.
Old Nov 19, 2008 | 08:56 AM
tmjvett2009's Avatar
tmjvett2009
St. Jude Donor '09-'10-'11
Default Storage
You can go one more step and get a bubble, I love mine, no moister, no varmits, no worries
Old Nov 19, 2008 | 03:47 PM
pmcvette's Avatar
pmcvette
thanks for the list and ideas
this is very helpful
Old Nov 19, 2008 | 05:10 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
Check Anti Freeze
Change oil? Filter?
Clean and Wax
I do pretty much the same except my cars are parked on vinyl so I don't use the carpet, and I only pump the tires up to 35psi. Neither of which is critical. The three most important things as far as I'm concerned are the Stabil, Battery Tender, and good cleaning.
Jeff Pedersen's Avatar
Jeff Pedersen
Check Anti Freeze
Change oil? Filter?
Clean and Wax
I will take that good advice myself.
Old Nov 19, 2008 | 06:28 PM
Red Rochester
Good Idea
Old Nov 19, 2008 | 07:52 PM
pmcvette's Avatar
pmcvette
can you explain the moisture gatherng material in the car
Old Nov 19, 2008 | 08:02 PM
miroch's Avatar
miroch
Would something like baking soda work?
Old Nov 19, 2008 | 08:36 PM
Joe_Knesek's Avatar
Joe_Knesek
Agreed!
Old Nov 19, 2008 | 10:18 PM
Kayvan's Avatar
Kayvan
Disabled by request 2 Jan 2009
Use U-Coat it on your garage floor...
It has a commercial grade hygroscopic rating that prevents any moisture
To Winter storage
