TPMS Question
Old Nov 19, 2008 | 12:30 PM
stoessjc's Avatar
stoessjc
Default TPMS Question
08 C6 Coupe. I changed rims and used bands to mount the TPMS sensor in each new rim. The TPMS system is telling me that my right rear tire is low (24 psi). I have measured that tire with two pressure gages (the cheap stick ones) and both indicate 30 psi. Has anyone else had this same experience?
I can't say for sure that I did not mix up the sensors when I put them on the new rims. If the sensors were not reinstalled on the same locations, could this cause my condition? Is there a way to reprogram the sensors if they were relocated incorrectly?
Thanks for any help.
John
Old Nov 19, 2008 | 12:47 PM
user051728's Avatar
user051728
John
Check all your tires for low air pressure.
Sensors don't move when your tires do.
Old Nov 19, 2008 | 12:48 PM
BEZ06's Avatar
BEZ06
John
John
Each sensor has its own unique ID#. When you program the sensors with the TPMS computer in the car you must do it in the order LF, RF, RR, LR if you want the DIC to display the pressures correctly. The first sensor you register will be considered to be the LF and that sensor ID# will be logged into the TPMS memory as the LF sensor.
If you put on new tires or swap the sensors to new wheels, you don't need to reprogram the sensors. However, if you do mix up the position then the DIC won't display properly, i.e. whichever one that was logged into the TPMS memory as the LF will still indicate "LF 30 psi" even if it's reinstalled on some other location.
So, check your other tires - one of them is probably down to 24 psi.
Bob
Old Nov 19, 2008 | 04:15 PM
stoessjc's Avatar
stoessjc
Thanks, I will check all four tires. Can you reprogram the sensors to correspond with new locations? Do you need the TPMS tool to do this?
John
Old Nov 19, 2008 | 04:25 PM
Zymurgy's Avatar
Zymurgy
Moderator
John
Yes and yes. However, some places like Discount Tire will reprogram them for free.
To TPMS Question
