First Oil change
Old Nov 20, 2008 | 01:57 PM
lnsaneM's Avatar
lnsaneM
Default First Oil change
I have a 08 Z06, with about 3500 miles, I haven't changed the oil yet. I'm wondering if I'm due for an oil change. I was told by a local dealer to change it when the light hits about 20% and I'm at 40% i think.
Is it time for an oil change? Am I still in the safe zone?
Old Nov 20, 2008 | 02:02 PM
cclive's Avatar
cclive
I like to do the first change at 1000, then I do it at 50% on the DIC after that. There is machining debris from manufacture in the oil at that first change, that is why I do it then. Later, a longer interval is fine.
But this is a point of disagreement here on the forum...so this is just my opinion, others most certainly will disagree.
Old Nov 20, 2008 | 02:05 PM
lnsaneM's Avatar
lnsaneM
Thanks I might take it in this weekend
Old Nov 20, 2008 | 04:58 PM
MAGDANA's Avatar
MAGDANA
That machining debris can be trapped with a FilterMAG. I would put one on at delivery and keep it on throughout the life of the car. I would also use Amsoil at the first change.
Joe Johnson
jj@magdana.com
Old Nov 20, 2008 | 05:06 PM
JessR's Avatar
JessR
every 3k miles for me.
Old Nov 20, 2008 | 05:11 PM
bimmerborn's Avatar
bimmerborn
I first changed at 1000. There was some little machining debris in the old oil.
Rogers 07's Avatar
Rogers 07
I disagree.......
Old Nov 20, 2008 | 05:13 PM
mksz51's Avatar
mksz51
Originally Posted by Rogers 07
I disagree.......
Well, I disagree with your disagree - in other words I agree with the original suggestions to change sooner. It's the cheapest and best insurance you'll ever buy.
Old Nov 20, 2008 | 05:17 PM
goatts's Avatar
goatts
I change mine every 5000 miles but it's not a bad idea to do first change early
Old Nov 20, 2008 | 05:55 PM
rjwoerheide's Avatar
rjwoerheide
I would change the oil now and not wait--especially if it's your first oil change on the engine. I did my first change at 89% oil life and 900 miles. I'm very liberal with my oil changes (never more than 3,000 miles and use synthetic oil) regardless of what the DIC tells me is left to the oil life.
The first change is important and your engine will thank you.
Old Nov 20, 2008 | 06:34 PM
Vietnam Vette's Avatar
Vietnam Vette
Either way you look at it, it's cheap insurance and will give you some peace of mind. Why risk it?
Old Nov 20, 2008 | 07:02 PM
cord arrow's Avatar
cord arrow
I use the mag...cut a filter apart on the band saw...good God you would not believe what that magnet can trap.
Magnetic drain plug as well...worthless compared to the filter mag.
Old Nov 20, 2008 | 07:40 PM
danl72's Avatar
danl72
I would do the first oil change at 1000 miles and then every 4000 or 5000 miles since you are using snythetic.
Old Nov 20, 2008 | 07:45 PM
Eppieguy's Avatar
Eppieguy
I plan on changing mine at 1,000 miles then at between 50% - 60% on the DIC, that's how I have done it on my Tahoe and it has more miles then I care to admit and after 3,000 miles the oil still looks as good as the day it went it. Always worked for me so I'll keep a good thing going!
Old Nov 20, 2008 | 08:37 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I personally do my first oil change on a new vehicle at about the 1000 mile mark, but then I've been taking the oil farther into the DIC that most of the above posters.
As an FYI that the OLM is actually pretty good, here are some used oil analysis reports on my 2006 CTS-V daily driver (LS2 motor) for which the OLM has been taken down to 25%:
Cadillac CTS-V Used Oil Analysis – Mobil 1 5w30 vs AMSOIL 0w30
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Nov 20, 2008 | 10:10 PM
Rogers 07's Avatar
Rogers 07
I agree with your disagrement of my disagrement..... or something like that
Old Nov 20, 2008 | 10:13 PM
philip_g's Avatar
philip_g
I also do mine at about 1000 or 1500 on a new car. On the woman's subaru I did a UOA on the first change at about 1700mi and it was unbelievable how much crap was in the oil. Molybdenum like woah and silica from the casting.
To First Oil change
Old Nov 20, 2008 | 10:18 PM
User 81424's Avatar
User 81424
Other than that first change every thing else in this thread is wasted money and time, just do what the DIC says.
Old Nov 20, 2008 | 10:20 PM
shopdog's Avatar
shopdog
I did the first oil change a bit early at 6,500 miles on the clock and 50% on the oil life monitor. I let it go longer now, typically 8,500 miles and 25% oil life, or about 3 times a year. Of course mine is a daily driver, and makes several long trips a year. That's a whole lot easier on a car than one that sits most of its life.
Old Nov 20, 2008 | 10:31 PM
johnhayesjr's Avatar
johnhayesjr
If you drive your car hard and always heating oil to max temps change more often. If you do the speed limit, 0 - 60 accelleration at around 10 seconds. drive in the granny lane. you can probably get 10,000 miles with synthetic. But if you drive the vette like it is intended to 3-4,000 tops.
