bose system
Old Nov 20, 2008 | 06:51 PM
biggn's Avatar
biggn
Default bose system
any one have info base system to bose system
Old Nov 20, 2008 | 07:41 PM
ALD_Z06's Avatar
ALD_Z06
As far as what?
Old Nov 20, 2008 | 07:54 PM
biggn's Avatar
biggn
Default re
have base system buying bose system and amp is wiring there to install it
Old Nov 20, 2008 | 08:36 PM
harddrivin1le's Avatar
harddrivin1le
Why bother?
Both the base system and the Bose system sound terrible.
You can connect a modified GM 24 harness to the stock head unit and use an aftermarket amp with REAL speakers.
http://www.lazyassgeek.com/c6-stereo...-pac-add-gm24/
It will blow the Bose crap out of the water.
Old Nov 20, 2008 | 09:18 PM
biggn's Avatar
biggn
Default re bose
but does it work base to bose
Old Nov 20, 2008 | 09:26 PM
harddrivin1le
No, it doesn't work. The wiring is different. You'd know that if you read the information in the link I posted:
http://www.lazyassgeek.com/c6-stereo...r-wire-colors/
Forget the Bose idea and do what I told you to do if you really want good sound. The Bose swap is a complete waste of time, money and effort. The system sounds like crap. Some say the stock stereo sounds better.
Bose builds junk; it's all marketing hype and no substance. Some of their (truly) professional stuff is decent, but ALL of their consumer grade stuff is absolute garbage and their OEM automotive stuff is the worst of all.
Refer to the audio section of this site if you want any more information:
http://forums.corvetteforum.com/audio-electronics-20/
Old Nov 20, 2008 | 09:42 PM
NYC6's Avatar
NYC6
You would be wasting your time anyway. The Bose is not that good anyway. You'll be better off putting some good components up front and get an amp for them and maybe add a sub. Check out the audio section.
Old Nov 20, 2008 | 11:06 PM
HANNY's Avatar
HANNY
i just added one ten and an amp and it really sounds nice with the factory unit. Ran it off the low line inputs off the head unit. Got all the info off the audio forum. There are some sharp VERY helpfull fellas over there.
A ten and an amp,,,I would start with that,,,the coupe has some awesome acoustics for a sub. Just a small amp and a ten can be very loud. As yo umay know the tweets and mids do ok but adding some more low's is really all you need IMO, with the stock unit and a sub i think you will be totally happy, good luck, paul
Old Nov 21, 2008 | 03:46 AM
chevyc6z51's Avatar
chevyc6z51
Hey Hanny could you pleezz pm. I would like to know everthing i need to do this and dont wont to for get to pick something up for the install. Im glad to hear you say it sounds good with this mod!! You also but 3 b.a in the front right??
Old Nov 21, 2008 | 06:38 PM
biggn's Avatar
biggn
Default re wiring
it says some wires are diffrent does not say if would work or not
Old Nov 21, 2008 | 11:43 PM
Grzldvt's Avatar
Grzldvt
I will second it is a total waste of time, you are going from bad to slightly less than pathetic. The best mod I did was to replace the Blose with real speakers and an amp. I also added an 8" sub to the left rear cubby, so my installation looks completely stealth and I did not lose any room in the hatch area at all. I retained the stock HU and the sound simply blows away the Blose system. It was a very simple setup to put together and in reality anyone can do it. Instructions are in the Audio section and if you find my post on the sub, you can see what I did
To bose system
