05 rattle help
Hi!
2005 Z51. On bumps I am getting a random rattle noise from the rear. I cant seem to figure it out. It almost sounds like it is the hatch. But I checked the screws and they seemed tight. Any ideas? Thanks.
Check the hatch handles. There are 2 screws that once they are loose, it creates a rattle once in a while. I had that problem is was driving me crazy. I ended up having the wife drive the car while I pushed my way to the back.
Good luck
Good luck
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Shaking the tips of the catbacks produces the same noise I hear inside, but I have yet to find the time to get it done.
I suspected it was the catbacks because once they got hot the rattle went away.
My fix for now is turn up my radio
Checked the sways. They are really tight. Definitely not them. I kicked the exhaust a bit. The left pipe squeeks a bit but I am not convinced that it is the same noise that I am hearing. I will just have to go for a cruise tomorrow to see if it is the same noise or not.....bummer. haha. I appreciate all of the help and will also check out the remaining ideas tomorrow. Thanks!!!!!
