My 2008 Coupe NPP experienced a "check engine" light which was diagnosed by the dealer as a "run lean" condition. Unfortunately, the dealer was unable to track down the source as their internet was down (couldn't access the troubleshooting sequence) and I need to take it back in.
Dealer said there was a possible vaccuum leak somewhere on the intake side or that a reprogramming might be necessary for the mass flow sensor.
I hope the dealer explained (and in case you didnt know) this is a very dangerous situation possibly causing a misfire.
Ironically, when I took it in to the dealer, the check engine light went out momentarily, but came back on which leads all concerned to think it might be a vaccuum leak due to a bad connection/hose. We'll see.
I had this same problem on my new '08.
Check engine light came on. Dealer reset it. Came on again.
They researched and found a TSB on '07s that indicated some holes on the header panel can cause turbulence in the intake track that the engine mistakes for a lean condition. There are four holes on eithr side of the air intake. They taped over the holes.
As a conclusion, I hope, today the dealer fixed the car. He uploaded the TSB for the "run lean" condition which didn't correct the problem. Then he switched out the mass flow sensor which appears to have done the trick. It looks like the left engine bank was running slightly lean.
No more check engine light.
I hope it was official gm duct tape....hey, how about 4 gm chicklets??
Has this condition happened with anyone else?
This is hilarious. They can't track down a lean misfire condition because their internet connection is down.
Yet they did seem to know a vacuum leak can cause this, though they apparently didn't look for a vacuum leak. The other things that can cause this are low fuel pressure (easily checked), or a faulty mass flow sensor (easily replaced). No internet connection required unless the mechanic has a hot role playing game he doesn't want to miss.
