Problems with my jack. Help Needed Please.
Old Nov 29, 2008 | 05:45 PM
S2K's Avatar
S2K
Default Problems with my jack. Help Needed Please.
I have a low profile Torin Black Jack. I bought this jack new more than a year ago. I've used it at least a dozen times with no issues. I store it in its hard case in a dry garage.
I have not used the jack in about 10 months and just pulled it out today to use it on the C6. However, the jack will not raise no matter how times I pump the handle. I checked the release valve and it is tight. I checked the hydraulic oil level and it seems full. In fact it runs out when I open the fill area so it seems very full. I've never added any oil so what is in there is what it came with.
The jack looks as good as when I bought it. There is no rust/corrosion/etc. I'd appreciate any thoughts as to what the problem might be.
Thanks a lot.
Old Nov 29, 2008 | 05:52 PM
bigdsz's Avatar
bigdsz
Probably a stupid question, however did you twist the handle clockwise?????? If you didn't you'll never get it to lift.
Old Nov 29, 2008 | 05:56 PM
S2K's Avatar
S2K
I think the twisting of the handle is just to ensure that the lever doesn't come out. I don't think it is necessary to get the jack to lift. Am I wrong here?
Old Nov 29, 2008 | 05:59 PM
S2K's Avatar
S2K
I should also add that I store the jack case on its side to reduce the space it takes. This of course means that the jack itself in the case is on its side. Not sure this matters and I don't recall seeing anything in the instructions about not doing this. Just trying to provide full disclosure.
Old Nov 29, 2008 | 06:04 PM
c7joe's Avatar
c7joe
The handle has to be twisted clockwise to close the valve. Then pump the jack. To lower it, twist counter clockwise slowly.
Old Nov 29, 2008 | 06:05 PM
rdm1465's Avatar
rdm1465
You might want to have somebody pump the handle while you work on pulling up on the lifting arm. Sometimes, when any Hydralic jack sits for long periods of time, the hydralic cylinder tend to stick. Hope this helps.
Old Nov 29, 2008 | 06:06 PM
c6 batmobile's Avatar
c6 batmobile
You do have to twist the handle to close the relief valve in the jack. It should stop twisting after a few turns. If that doesnt work the jack may have poor tension on the relief valve spring or a bad check valve on the internals. Either way it wont work with out rebuilding it.
Old Nov 29, 2008 | 08:48 PM
S2K's Avatar
S2K
Appreciate the help. However, I think there is a misunderstanding about my jack. The release valve is NOT in the handle. There is a little t-nut that sits on the jack just below the handle. To release the pressure and lower the jack you have to turn that counter clockwise. To close the valve it has to be turned clockwise. I usually have to use a pliers as it tends to stick. Anyway, my point is that the release valve is not in anyway connected to the handle.
I can lift the jack up a bit with my hands and then lower it with the aforementioned t-nut. However, pumping the handle does nothing.
Old Nov 29, 2008 | 09:33 PM
cclive's Avatar
cclive
If its like this Torin Black Jack, you twist the handle to open and close the valve. It wouldn't make any sense for a mechanic to have to reach all the way under the car to release and lower it on the body of the jack. He doesn't want to be anywhere near the body of the jack when he is lowering the car. You can see the gear that transmits from the turning of the handle in this pic.
Old Nov 29, 2008 | 09:36 PM
ZPO's Avatar
ZPO
Sounds like the same problems I had with some old bottle jacks. I think the internal pump piston is full off air. Try leaving it set upright with the release valve open overnight or leave the release valve open and pick up the lifting arm up slowly and releasing it to try to get some of the air out of the piston chamber. Other than that check the linkage of the pump handle to the pump piston.
Just my 2 cents.
Old Nov 29, 2008 | 10:18 PM
AVnerdguy's Avatar
AVnerdguy
I believe I have the same jack.You definately need to twist the handle to close the valve. Try opening it all the way (counterclockwise) and push the lift mechanism down by hand to get any air out then close the valve by twisting the handle (clockwise) till it stops. You were probably trying to compress the air instead of the fluid and couldn't get any lift.
Old Nov 29, 2008 | 10:29 PM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
depending on the jack there is an air bleed valve.
Do you have your owner instructions? It will have a maintenance procedure or try searching online for the owners guide.
Old Nov 29, 2008 | 11:12 PM
S2K's Avatar
S2K
Guys, I am telling you the release valve is NOT in the handle. I have used this jack a dozen times at least. I do have the instructions still. There is a release valve under the handle and to the left. This is what opens and closes the valve. My jack is not the like the jack pictured above.
I will try to leave it upright with the valve opened as suggested above. We'll see what happens.
Thanks for the continued help.
Old Nov 30, 2008 | 02:37 AM
statman's Avatar
statman
NoCA Events Coordinator
I don't have the jack that you have, but the one I have did the same thing after several years of light use.. I fixed the problem by adding hydraulic jack oil, purchased at Wal-Mart for a couple dollars. Works great now.
This problem got me thinking about puechasing a better jack, and I found a great deal on one at Costco. Man, what a great jack, and it was only $90.
Old Nov 30, 2008 | 10:48 AM
05_Black_Z51's Avatar
05_Black_Z51
Originally Posted by ZPO
...Try leaving it set upright with the release valve open overnight or leave the release valve open and pick up the lifting arm up slowly and releasing it to try to get some of the air out of the piston chamber. ...
I'll try that with my Craftsman. It worked once, then would not go up, on a cold day if that matters. I brought it in to warm up. but no luck.
Old Apr 27, 2017 | 09:13 AM
Mark Murphy's Avatar
Mark Murphy
1st Gear
I have a Torin Black Jack 2 and half ton Jack that I had in back of my pickup. The pump piston rusted and doesn't move. Where do I get a new part? Marc
Old Apr 27, 2017 | 09:31 AM
Narddog's Avatar
Narddog
You bumped a 9 year old thread, to ask a question about a floor jack that's been in the back of your pickup, on a corvette forum?
A quick Google search shows Torins are cheap, Wal-Mart jacks. I'd pick up a new jack as I wouldn't trust that on that's been weathered and probably cost you less than $40 to begin with.
To Problems with my jack. Help Needed Please.
Old Apr 27, 2017 | 10:22 AM
unclecookie's Avatar
unclecookie
Damn, I get sucked in every time. I always forget to look at the op's posting date.
Old Apr 27, 2017 | 10:43 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
And that was "Mark Murphy's" very first post here on the Corvette Forum.
Old Apr 27, 2017 | 11:55 AM
Narddog's Avatar
Narddog
Haha, I always wonder how they end up doing that. Probably just google searching for parts and this forum pulls up due to keywords.
