question, please read
Old Dec 4, 2008 | 11:25 PM
spin-doktor's Avatar
spin-doktor
Default question, please read
Lately ive noticed my oil pressure gauge going higher than usual, especially when the car is cold, on cold days. It will surge to 60 psi and even to 80 psi sometimes. The surging is consistent with RPM's. At idle, pressure is a little under 40psi. Im using royal purple 5-30 and a K&n oil filter. Once the car warms up the pressure stays around 40 PSI and does not surge anywhere past 60psi even when i hit the higher revs.
I checked the oil level and its within the crosshatch area.
Is this oil pressure surging normal or does my car have a problem ? (bad oil ? clogged oil filter ? )
2007 C6
Old Dec 4, 2008 | 11:30 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
don't think it's anything to worry about. even 5w-30 gets a little thicker with cooler weather (try Minnesota in the winter if you want really thick oil!). thicker oil means higher pressure. as it warms, it thins.
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Normal, the colder the oil the higher the initial pressure.
Old Dec 4, 2008 | 11:55 PM
HANNY's Avatar
HANNY
its normal but damn annoying when cold isnt it? Got an 09 does the same damn thing. No worries bra
Old Dec 5, 2008 | 01:40 AM
c6 batmobile's Avatar
c6 batmobile
If you let the car warm up more before you drive it you wont notice the surge. I let mine warm up for about 6 mins before I drive it (its modded as well) and I dont get oil press. surges. But it is normal.
Old Dec 5, 2008 | 04:56 AM
keyplyr's Avatar
keyplyr
Sometimes here in San Diego the temps can plummet as low at 60°. I feel your pain bro...
Old Dec 5, 2008 | 11:33 AM
mikesul's Avatar
mikesul
The oil is more viscous at lower temps, shows higher pressure until the oil gets warmer.
Old Dec 5, 2008 | 11:42 AM
Red Cell's Avatar
Red Cell
Normal.
Suggestion, do not go WOT until you are at operating temperature. I usually keep mine under 2500RPM (or lower) until that time. Depending on the temperature outside, it could take up to 10-15 minutes.
Red Cell.
Old Dec 5, 2008 | 12:22 PM
mksz51's Avatar
mksz51
Play nice...................
Old Dec 5, 2008 | 12:33 PM
C6NRED's Avatar
C6NRED
Originally Posted by Red Cell
Normal.
Red Cell.
...Most here say to let your oil temps get to at least 160 degrees before going WOT, and you will have higher PSI until then with colder oil -- perfectly normal............Lots of past posts on the subject or oil temps and pressure........
Old Dec 5, 2008 | 12:43 PM
Rogers 07's Avatar
Rogers 07
Speaking of gauge problems, Ive noticed that one of the big gauges in the middle moves every time you push the gas peddle.... weird!!!
Old Dec 5, 2008 | 12:57 PM
Dave@Ciocca's Avatar
0Dave@Ciocca
Former Vendor
Where's the little smilely face givng the finger when you need it?
Old Dec 5, 2008 | 01:40 PM
LarryMJones's Avatar
LarryMJones
Veteran: National Guard
St. Jude Donor '13-'14-'15-'16-'17
Default Here he is
LJ
Old Dec 5, 2008 | 01:44 PM
Rogers 07's Avatar
Rogers 07
Originally Posted by LarryMJones
LJ
To question, please read
