Run Flats
Old Dec 9, 2008 | 10:11 AM
DP1940's Avatar
DP1940
5th Gear
Default Run Flats
My tires constantly leak down, (all four at about the same rate) on my 08 C6. Is this a normal thing?
Old Dec 9, 2008 | 10:18 AM
2vettes's Avatar
2vettes
No, it's not normal.
Old Dec 9, 2008 | 10:22 AM
AFVETTE's Avatar
AFVETTE
I'd suggest you mix up some soapy water and apply it to the valve stems and look for bubbles. It could be that the nut that secures the valve stem (TPMS) is loose.
The other thought could be your car is now exposed to colder air temps (which lowers the PSI and could trigger a LOW TIRE message) causing your situation. In that event set your tire pressures to 30 PSI COLD. And I mean COLD, like early in the morning after the car has sat over night. In the winter I usually add a pound or two to be safe.
But for ALL FOUR Tires to exhibit the EXACT same lose is ODD to say the least. Good luck
Old Dec 9, 2008 | 10:29 AM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
It's cold weather
If there was a true leak - they would go flat eventually.
Old Dec 9, 2008 | 10:38 AM
xlr8rvette's Avatar
xlr8rvette
From: Fayetteville Arkansas recently moved from Oakland Ca
St. Jude Donor '06
Had the same loss of pressure occur on my second set of tires. Did this for first 15k miles, then seemed to be ok. Third set seems okay, however, they are real sensitive to cold temperature changes.
Good luch
Old Dec 9, 2008 | 10:41 AM
JoesC5's Avatar
JoesC5
You can expect the tire pressure to drop ~1 psi for each 10 degree temp drop. In the winter I fill my tires(on all my cars) about 3 psi over the mfg recommended pressure to allow for this and also because in the winter, the tire does not heat up as much during driving. Take your vette, that the factory recommends at 30 psi cold. On a warm/hot summer day, the pressure will go up to around 35 psi. the fasctory recommendation allows for this. In the winter it will only increase by around 2 psi(up to 32psi from the recommended 30 psi). So, I inflate my C6 tires to 33 psi cold, and when the get up to operating temp they are reading 35 psi. The same as in the summer.
Old Dec 9, 2008 | 10:46 AM
metal's Avatar
metal
I have the same exact problem with my 08, less than 1000 miles. I am losing about 1# per week and will have to take my car in to see if this can be corrected.
Old Dec 9, 2008 | 10:50 AM
rjwoerheide's Avatar
rjwoerheide
1,100 miles on my run flats and no leakage present. They were, however, low when the temperature dropped in November. I added air for the cold season and the pressure hasn't dropped since.
Good luck!
To Run Flats
