water spots
Old Dec 11, 2008 | 11:04 AM
tommy grantham sr.'s Avatar
tommy grantham sr.
Default water spots
I have wax my car 3 times,under the lights I can see several what I call water spots. any ideas.tommy
Old Dec 11, 2008 | 11:08 AM
mksz51's Avatar
mksz51
Clay bar may do it - may also need a more aggressive polish to remove them.
Old Dec 11, 2008 | 11:15 AM
RED2008Z06's Avatar
RED2008Z06
I seen white vinager and water...good luck
Old Dec 11, 2008 | 11:19 AM
freyke's Avatar
freyke
Old Dec 11, 2008 | 11:21 AM
Daytona Bob's Avatar
Daytona Bob
St. Jude Donor '09 & '12, '14
I had to use a cleaning polish and I thought I was running a marathon when I was done. People don't understand how hard florida water is and all the crap in it. If a lawn sprinkler hits your car - its OVER.
Our Water table is 6 feet below the ground.
Old Dec 11, 2008 | 11:23 AM
orca1946's Avatar
orca1946
Do you hand buff or orbital buff?
Old Dec 11, 2008 | 11:26 AM
Daytona Bob
Hand for me. I don't trust myself with a machine touching the vette.
Old Dec 11, 2008 | 11:35 AM
danl72's Avatar
danl72
Old Dec 11, 2008 | 11:36 AM
tjl5709's Avatar
tjl5709
I see your in Florida. The spots could be two different things depending on what water caused it.
If it's water from a hose (washing the car), it could be simple salts from the water being left behind when the water evaporates (simple water spotting). You may have waxed over them and kinda sealed them in. Clay bar should work, or wash with Dawn to strip the wax, and try alittle vinegar from the kitchen on a rag to see if it desolves them. If they remove with the vinegar, it's simple water spotting, and its an easy fix.
Worse could be acid etch from rain. When rain water evaporates, it can contain a small amount of acidity that increases in concentration. This acid concentration can get so strong that it degrades (acid etches) the clear. Although we have a good 2K urethane clear from the factory that is designed to be resistant to this, you live in an environment ripe for this situation (rain & hot sun cycles [dark colors are worse]). If the above does not work, this could be the problem. If it is, a professional wheel-out maybe required to remove the layer of etched clear if it is unexceptable to you.
Old Dec 11, 2008 | 03:25 PM
Fastcar's Avatar
Fastcar
It is a pia to get off.
Old Dec 11, 2008 | 04:17 PM
Daytona Bob
Yea I was all excited to do the vinegar thing. The spots just laughed at me. I was like WTF? I then used a claybar...once again the spots were like not even close to going away.
Heck I even took it to a professional car wash place - they couldn't remove it...and said No Dice unless I did the full detail and buff.
This is just from sprinkler water blowing back on the car. (My sprinkler is city water btw) I can't imagine well water or "Baked in" water spots.
I hate water spots. Maybe I need a whole house treatment system.
BTW I have a pool so when I test the water chemistry in my home I have hard water. So I guess they are hard to remove due to calcium?
Old Dec 11, 2008 | 04:39 PM
tjl5709's Avatar
tjl5709
If vinegar is not taking it off, it's not simple water spotting. Calcium deposits and simple salts would be removed.
It sounds like the water treatment plant is leaving some residual chemicals in the water, and upon evaporating in the hot Florida sun you are raising the concentration to the point that it's attacking the clear in some way.
In the studies done on developing the etch resistant clears for todays cars, it was found that drops of rain water that condense down during evaporation, they would turn into a more concentrated acid then that found in your car battery. Combined with the heat generated from the sun, it would eat the top layer of the clear away.
Old Dec 11, 2008 | 04:43 PM
GotVett?'s Avatar
GotVett?
Yep. I started a threat a couple of days ago about not driving in the rain, for the same reason. Really don't want to go through the same PITA "extra" effort trying to get dried water spots out, especially on a hot hood.
Old Dec 11, 2008 | 04:47 PM
4thC4at60's Avatar
4thC4at60
It seems as if you have waxed over the water spots. If that's the case you're going to have to remove the wax in order to get to the water spots. Once you strip the wax from your car you can remove the water spots with vinegar. Until you remove the wax you're not going anywhere.
Old Dec 11, 2008 | 04:51 PM
Daytona Bob
Rain water comes right off (distilled naturally) and I dont have any acid rain where I live.
The water from the treatment plant is another story! Thats good info thx.
Old Dec 11, 2008 | 06:26 PM
Fastcar's Avatar
Fastcar
I have a whole house water softner system for sale. PM me if your interested.
Old Dec 11, 2008 | 09:04 PM
tommy grantham sr.
how do you removed the wax
To water spots
Old Dec 11, 2008 | 09:23 PM
gdreager's Avatar
gdreager
2nd Gear
I had the same problem when my black 07 was new off the lot. The dealer apparently did not dry it, and the water spotted. I bought the car in San Diego, and live in Arizona. When I noticed that spots, I tried the usualy stuff, and nothing worked. Then I decided to use, I believe it was McGuires No. 1, polish. I rubbed by hand, and rubbed and rubbed and rubbed. I finally saw signs if it coming off, and kept on rubbing. It was on the upper 1/2 of the hood, and probably took 3 hours to get it off. Good Luck!
Old Dec 12, 2008 | 06:52 AM
BlackZ51Vett's Avatar
BlackZ51Vett
Try the "Car Care" forum. Owning a black car, I've picked up a lot of tips there on keeping it clean.....
Old Dec 12, 2008 | 08:59 AM
tjl5709's Avatar
tjl5709
You do, but it's not as much as a problem than say, Jacksonville. Most rain is naturally acidic. We just help it out by burning hydrocarbons.
