Awful subject for my first post, came out to my car after work today to discover that my right rear Z51 Supercar went flat. Was too late at night to get it to the dealer so drove it 3mi home. 12mi drive to the dealer in the morning.
Question: Is it a problem that it will sit overnight or will the runflat not be troubled by that? Never had a runflat go flat before and can't find the answer on Google. If it's relevant the puncture is from a screw embedded at the intersection of tread in the middle of the tire, there's no sidewall issue.
that's a good question. if you can, add air to the tire. it can't hurt.
by dealer I presume you mean Goodyear dealer. most car dealerships won't/can't deal with tire repairs as well as a Goodyear dealer. call tire places first to find out if they handle runflat. or it might be in the tire booklet that came with the car.
Nimo, not a problem you can leave it and then in limp mode drive to your dealership. Being in the center of the tire it can be repaired, a plug and patch is recommended.
However I plugged my tire and that was about 8K miles ago no lost of air and it has withstood speeds of 150, 155 and 160 (closed roadway).
Thanks for the advice! There's an air station a block away so I'll be sure to fill it up.
I'm taking it up to Criswell in Gaithersburg, I had called them and they told me to bring it up in the morning and didn't mention not having replacements. They've been A++ on all my dealings with them so I trust them to do a good job.
Welcome to the forum Nimzowitsch! I agree, like you said, Criswell in Gaithersburg, MD is an excellent dealership. I purchased my C6 from them and had rear-end differential fluid recall work done there. Absolulety no problems at all- great people. They'll take good care of you and your Vette.
Now's your chance to get rid of those awful tires and get some decent performance rubber on your Corvette. Don't miss this opportunity being presented here
Hmmm - I'm reading some bias in your comments.....
This summer, I punctured my right rear tire. I was 12 miles from home. Knowing I had 0 psi in the punctured tire (I have the Supercar tires that come on the Z51), I drove it home at 45 mph. I had the puncture repaired.
I was under the impression that if you did not drive over 55 mph and did not drive over 25 miles, the EMT tire would survive. Well, after the tire was repaired, it was very noisy. It sounded like a worn bearing in the differential. Very annoying, so I ended up buying a new set of the Goodyear Supercar tires. It was close to time anyway.
I was disappointed, because I though driving at 45 mph for 12 miles would not damage the tire. But it did. Yes, it got me home OK, but not without some unexpected tire damage. I though run flats could be driven flat for short distances at low speeds and hold up. Did I miss the point of run flats?
As per the Owner's Manual:
The shorter the distance you drive and the
slower the speed, the greater the chance that the tire
will not have to be replaced. If you drive on a deflated
run-flat tire for 25 miles (40 km) or less and at speeds of
55 mph (90 km/h) or less, there is a good chance that
the tire can be repaired. The tire can operate effectively
with no air pressure for up to 100 miles (160 km) at
speeds up to 55 mph (90 km/h), but the tire would then
There is NO GM, Chevy or Dealership Warranty on the tires. Goodyear has the Warranty, only authorized Goodyear shops can repair or replace the runflats under warranty.
For a quick, easy repair go to the nearest Discount Tire, they repaired mine for free.
Had my right rear on my 09 replaced at dealer under warranty. Some dealers not all have the trained tech to do this in my case it was the Corvette tech.
z51vett
Almost any performance tire that fits the Corvette will no doubt give better results in handling, ride quality and price. Use the forum search. Lot's of information in these archives.
I personally like the safety factor of run flats. Lose air quick with a non run flat and you can almost kiss your rim good-bye and the tire stands a chance of being damaged if left without air. Corvette wasn't designed to be MB or Lexus.
I believe that "safety" is falsely assumed. Plenty of accounts that disprove this hyperbole.
Also, plenty of threads with arguments for/against
Not sure what happened on your case. But on mine it was a Sunday I took my wife to work and after I dropped her off as I was driving around I got a low pressure warning to my left front tire. I started to head home and then the warning went to left front tire FLAT, I pulled into a shopping center and looked and there was a screw in my tire. I had to drive about 8 miles to get home on a flat tire but the run flats held up, once the tire is flat the computer will allow you to drive in reduce power mode, meaning you cannot go faster then 50 mph. I repaired my own tire and haven't had a problem since the repair. This was 8K miles ago and the tire is still running strong but alas nearing the end of it's thread life.
There's a pretty nice write up on Michelin's new run flats called ZP or some such here in C6 Gen. An alternative to the Goodyear runflats, and the Firestone runflats, both of which fit our Corvettes.
Yes, I do not understand why driving at 45 mph for 12 miles caused the run flat to become excessively noisy. I was well below both the max run flat speed and driving distance for the Goodyear EMT while at 0 psi. Since that event, I am now much less enthusiastic about the Goodyear EMTs. I feel the tire did not do what it was advertised to do. While I was able to drive at 0 psi for 12 miles, I was not able to drive at 0 psi without somehow damaging the tire.
