Warming up
Old Dec 21, 2008 | 10:03 PM
saibel's Avatar
saibel
Default Warming up
How long do you warm up your cars before you begin to drive it. Is there a temp that you require the engine to be at before you begin?
Old Dec 21, 2008 | 10:06 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Just drive it easy for the first few miles. It's better for your car than letting it sit and warm up.
Old Dec 21, 2008 | 10:10 PM
Marc V.'s Avatar
Marc V.
Start it up and drive. It will also warm up faster when driven than at idle.
Vette_DD's Avatar
Vette_DD
No, no warm up before I drive. I just drive slowly for the first couple of minutes. It helps that I live in an area where I have to drive several 30 mph roads before I get to higher speed limit roads.
Old Dec 21, 2008 | 10:22 PM
saibel's Avatar
saibel
Thanks for the input so far, why is it better to drive easy at first, specifically?
Old Dec 21, 2008 | 10:26 PM
Timjoom's Avatar
Timjoom
I wait until the navigation screen is active and I can touch the "I accept" button which is probably around 30 seconds after start up.
TBD's Avatar
TBD
Same reasons one would drive any vehicle at "easy" speeds until it's properly warmed up...absent exigent circumstances, of course.
Peace, out.
Old Dec 21, 2008 | 10:29 PM
sajonf's Avatar
sajonf
I usually pull out of the garage and sit in the driveway until the garage door closes completely, I get my seatbelt fastened and everything situated. Usually a minute max. Then I just drive the car easy until the temperature comes up.
Today I let it idle a little longer since it was 7 degrees for a high in Kansas City
Old Dec 21, 2008 | 10:41 PM
spin-doktor's Avatar
spin-doktor
i try to let it idle for a couple of minutes and then drive it real easy till it reaches op temp
Old Dec 21, 2008 | 10:44 PM
saibel's Avatar
saibel
I have been letting it idle until the temp reads 90, then drive easy until temp gets to 100. Seems to be a but different.
Old Dec 21, 2008 | 10:53 PM
patton's Avatar
patton
St. Jude Donor '09
Old Dec 21, 2008 | 11:35 PM
Maui's Avatar
Maui
St. Jude Donor '08
I let it warm up for about 30 seconds to a minute. I ease out of the garage and wait until the door is completely closed. I don't drive it hard for the first mile or so.
Old Dec 21, 2008 | 11:38 PM
larvette's Avatar
larvette
Old Dec 21, 2008 | 11:43 PM
GotVett?'s Avatar
GotVett?
That's what I do also.
Old Dec 21, 2008 | 11:56 PM
JohnRS's Avatar
JohnRS
I drive mine right away without an idle warm up but I don't exceed 2500 rpm until the oil temp is 170 - 180 degrees. ---John
Old Dec 21, 2008 | 11:58 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Usually just crank it and go -
Old Dec 22, 2008 | 12:06 AM
phileaglesfan's Avatar
phileaglesfan
Just put it in gear and move.
To Warming up
Old Dec 22, 2008 | 07:15 AM
gota07's Avatar
gota07
Cruise-In VIII Veteran
Driving the car under light acceleration will get the engine up to nominal operating temps faster than sitting still.
Old Dec 22, 2008 | 07:47 AM
SlideRulz's Avatar
SlideRulz
I wait till the coolant is 100 then take it easy till all temps are normal.
Old Dec 22, 2008 | 09:48 AM
dvilin's Avatar
dvilin
