HELP...Harmonic Balancer Bad???
Old Dec 28, 2008 | 01:37 PM
fmcokc's Avatar
fmcokc
Default HELP...Harmonic Balancer Bad???
Is this what a bad Harmonic Balancer looks and sounds like?
Just started doing it.
07 Z51 A6 with 40K miles.
Thanks in Advance...
Old Dec 28, 2008 | 01:56 PM
Silver05GTO's Avatar
Silver05GTO
Mine has a slight wobble too, but no noise from it. Think I may be needing a trip to the dealer soon if it gets any worse. My 07 has 23K miles.
Old Dec 28, 2008 | 02:11 PM
Walt White Coupe's Avatar
Walt White Coupe
Excessive wobble will cause the belt to chirp at idle. It's not a steady sound but a chirp, chirp, chirp, etc. Not sure how to describe yours but it doesn't sound like the chirp mine made when the flex coupling in the harmonic balancer failed. In the ideal world that balancer would run completely true and the ribs will look stationary with the engine idling. One of the problems, I learned, is that there is no limit/specification to define an out of tolerance measurement for balancer wobble.
You might want to try and electrically disable the alternator (because it's easy to do) and see if that causes any change to sound you are hearing. It might be an alternator bearing that is the problem.
Just throwing this out there but your noise sounds like an exhaust leak to me.
Old Dec 28, 2008 | 02:12 PM
DSOMvette's Avatar
DSOMvette
St. Jude Donor '09
I believe I would get to the dealer sooner than later, the way that sounds
Old Dec 28, 2008 | 02:17 PM
300mph's Avatar
300mph
That has the characteristic sound of a bad idler/tensioner pulley .
Old Dec 28, 2008 | 02:21 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Old Dec 28, 2008 | 04:52 PM
fmcokc's Avatar
fmcokc
The sound didn't come through very well.
It is definitely a chirping sound that is in time with and coming from the crankshaft pulley.
Old Dec 28, 2008 | 04:54 PM
Hairbag's Avatar
Hairbag
Nice choo choo train you have there.
Old Dec 28, 2008 | 05:03 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
I HATE dealers. I DESPISE dealers. I'd rather have a root canal while my toenails were being pulled out with rusty pliers before I'd go to a dealer for ANYTHING.
Get to a dealership quick. That has to be covered by warranty.
Old Dec 28, 2008 | 05:04 PM
Stingbill's Avatar
Stingbill
Your post is not helpful but very funny !!!
Old Dec 30, 2008 | 07:17 AM
Hairbag's Avatar
Hairbag
Sorry. You want helpfull. Take the belt off and start the car to better understand where the sound is coming from. Give the idiler a spin with the belt off. Then take it to the stealer with some knowledge of your own as to what may be wrong.
Old Dec 30, 2008 | 08:39 AM
Rock-it Man's Avatar
Rock-it Man
Don't start the car with the belt off!!!!
Old Dec 30, 2008 | 08:49 AM
scgene's Avatar
scgene
I think the Harmonic Balancer bolt problem goes well past the early 05's. I have a friend with a 07 and its been to the shop 2 times with the bolt backing out. I was with him the second time and it sounded a lot like your car.
Old Dec 30, 2008 | 09:56 AM
C8-Vette's Avatar
C8-Vette
Why? Would it cause a problem? Let us know.
Old Dec 30, 2008 | 10:04 AM
Walt White Coupe
With the belt off you are not turning the water pump so the engine will overheat very quickly. A run of 15 seconds or so would be no problem for a test.
Old Dec 30, 2008 | 06:21 PM
Hairbag's Avatar
Hairbag
For 30 seconds to help eliminate where the sounds coming from won't bother a thing!
To HELP...Harmonic Balancer Bad???
