Replacement Battery
Old Dec 29, 2008 | 05:39 PM
357's Avatar
357
Default Replacement Battery
What is the groups opinion of the best replacement battery for a C6?
Thanks in Advance
Old Dec 29, 2008 | 05:47 PM
VettedCandidate's Avatar
VettedCandidate
AC Delco is what I replaced the original with and it has worked just like a good battery should, for a lot less than some of the others.
Old Dec 29, 2008 | 05:48 PM
TN 2005 C6's Avatar
TN 2005 C6
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Here are a few that I found using the search function:
http://forums.corvetteforum.com/c6-c...ellow-top.html
http://forums.corvetteforum.com/c6-t...comations.html
http://forums.corvetteforum.com/c6-c...nt-advise.html
http://forums.corvetteforum.com/c6-c...t-battery.html
http://forums.corvetteforum.com/c6-c...t-2005-c6.html
Old Dec 29, 2008 | 05:53 PM
x-mann's Avatar
x-mann
easiest to get, one of the best warrantys, is the SEARS Platinum series. i looked at all the others, this battery is built the same as the "best known brands" w/ the gell instead of liquid, its available at your local sears store, comes w/ a 4 year full replacement and a 4 year prorated replacement after that. it blows away the ac delco, i would never put another one of those in my car. i had nothing but problems w/ it.
the sears platinum series runs about 200.00, highly recommended. i have had mine in my car for about 1 1/2 years, never had any issues w/ it. i live in CA, desert, 105deg all summer, work in palmdale, ca it gets below freezing in winter always fires up strong!
danl72's Avatar
danl72
AC Delco, Diehard, and Optima are all good batteries.
Old Dec 29, 2008 | 05:56 PM
timd38's Avatar
timd38
It is not a gell battery it is an AGM battery. BIG difference. AGM is vastly better than gell. Warranty is a function of marketing, not product quality.
I have an Optima group 35 in my car and an Optima is about $40.00 less than a Sears battery.
Old Dec 29, 2008 | 07:17 PM
crazyeddie's Avatar
crazyeddie
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13
eddie
Old Dec 29, 2008 | 07:34 PM
larvette's Avatar
larvette
Old Dec 29, 2008 | 08:31 PM
terrymccoyc6's Avatar
terrymccoyc6
got a battery from a local shop"bell city battery"for about $80 installed.been in car about a year no problems.
Old Dec 29, 2008 | 08:33 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Battery just died in my '07 and had it replaced under warranty.
Have a Sear Diehard Platinum in my C5Z06 and it has been killer!
If I need to replace the battery in the C6 out of warranty, I'll drop one of those in.
Old Dec 29, 2008 | 09:02 PM
VET4LES's Avatar
VET4LES
Optima Red top for me.
Old Dec 29, 2008 | 09:15 PM
rick g's Avatar
rick g
Old Dec 29, 2008 | 09:55 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
I've always had good luck with Interstates.
Old Dec 29, 2008 | 10:17 PM
bencini231's Avatar
bencini231
Old Dec 30, 2008 | 12:06 AM
timd38's Avatar
timd38
All are made by Johnson Controls.
Old Dec 30, 2008 | 12:07 AM
timd38's Avatar
timd38
Also made by Johnson Controls.
Old Dec 30, 2008 | 12:29 AM
avizandum's Avatar
avizandum
I had an Optima yellow in another vehicle and it was junk.
To Replacement Battery
Eritosthenes's Avatar
Eritosthenes
If you're talking about the little place on S. Charles St. in Belleville I heartily agree with you, but unfortunately it's not really accessible by folks outside the St. Louis metro area.
Old Dec 30, 2008 | 08:16 AM
vetdude's Avatar
vetdude
Any battery with the built-in carrying strap for a C6Z. If you've ever seen how these things are wedged into the rear storage hold you'd uunderstand.
We did replace the battery in the wife's C5 over a year ago with a Sears Diehard and have had zero problems, even after the car has been sitting for weeks. Can't do that with the Delco in the Z06.
Old Dec 30, 2008 | 09:03 AM
08jetvette's Avatar
08jetvette
http://braillebattery.com/index.php/batteries/b6034/#
Heres another option for you. Bowmanized is a supporting vender that can fix you up.
