Is It Time Yet?
Is It Time Yet?
My 08 is asleep for the winter. I know it is early to be talking about firing her up - but - what is the best way to do so?
I have been storing cars for the winter since 1969. I never started them during the winter, always feeling this would do more harm than good. For one thing, it would be impossible to fully warm up the motor, and that's not so good for the motor and the exhaust system. Then there is the issue of carboning up the heads, etc.
When spring arrived. I used to pull the coil wire (remember those), boost the battery with another vehicle, and begin a slow cranking on/off cycle until the oil pressure gauge was up there. Then I would reconnect the coil wire, and start the car, letting it run for 10 seconds, and shut it off. I would repeat this cycle a few times, and then I was ready to rock and roll.
I was always worried that the rings would 'stick' to the cylinder walls after sitting in one place for about 4 months. Maybe I should have squirted oil in the cylinders prior to storing, and then again prior to cranking, but I never did. I never had any ring issues.
With my STS, I pull the coil fuse and crank for a few seconds, wait 10 or more seconds, and repeat this cycle a few times.
Is this necessary in today's motors? For those who do store their C6s, how do you deal with this?
It kills me to look at this beast and not be able to use it!!
Thanks for this superb forum. Happy New Year to all.
M.......
M.......
For me I remove the cover, unhook the battery Tender, fire it up let it idle for a couple of minutes and take it for a short cruise. Also inflate tires if necessary.
Had mine out two days ago after sitting for two months. It was cold but the streets were dry and the sun was out (for a while anyway). Just fire it up, let it warm up for 10-15 minutes and go.
Now back under the cover and on the battery tender for another couple of months, got 6-7 inches of snow overnight.
