Headlight Assembly
Old Jan 1, 2009 | 11:00 AM
HOTSOSS's Avatar
HOTSOSS
Default Headlight Assembly
The headlight assembly (right side) on my 08 is loose. I don't see where I can access the mounting hardware, can anyone tell me? Thanks.
Old Jan 1, 2009 | 11:04 AM
patton's Avatar
patton
St. Jude Donor '09
3 volume helms manuals
Old Jan 1, 2009 | 11:17 AM
calemasters's Avatar
calemasters
The fasteners are obscured by the front inner wheel housing and fascia.
Procedure to R&R the headlamp as per the service manual:
Open the hood.
Remove the six upper fender flange bolts from the side the headlamp is being serviced from.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the front wheelhouse liner. Refer to Front Wheelhouse Liner Replacement .
Remove the front bumper fascia. Refer to Front Bumper Fascia Replacement .
Remove the three lower headlamp nuts from the front wheelhouse panel.
Disconnect the headlamp electrical connectors from the headlamp.
Lower the vehicle.
Lift the front corner of the fender and raise the fender approximately two inches, enough to lift upward on the headlamp and release the studs from the wheelhouse panel in order to remove the headlamp from the vehicle.
Old Jan 1, 2009 | 11:27 AM
HOTSOSS's Avatar
HOTSOSS
Open the hood.
Lower the vehicle.
Thanks. I think I'll let GM do this under warranty.
Old Jan 1, 2009 | 12:01 PM
JJC5's Avatar
JJC5
My sentiments exactly!
To Headlight Assembly
