Cross Beam Adapter
Old Jan 7, 2009 | 09:43 AM
STEVE MC's Avatar
STEVE MC
Originally Posted by Motorhead-47
$42.95 at Summit and unlike the Northern Tool copy, the center shaft in the Summit model fits many common jacks without modification!
http://store.summitracing.com/partde...5&autoview=sku
Wish I had known that before I bought the one from Northern Tool. Luckily, I have access to a toolroom and I was able to modify the shaft with an external boring tool in a milling machine. PIA
I also afixed rubber to the top of the crossmember because the extensions are useless for jacking the front.
Old Jan 7, 2009 | 10:08 AM
Motorhead-47's Avatar
Motorhead-47
I lopped off the threaded adjusters from the plates on each extension and then welded each plate to the ends of the center section. I then reattached the rubber pads to the newly welded plates using the original mounting screws. This works perfectly on the front. The extensions I now use as resting places for a pair of 6 ton jacks which securely cradle the entire setup. Works like a charm on the front.
Old Jan 7, 2009 | 10:13 AM
Vet's Avatar
Vet
That sounds cool.... you should post pics.
Old Jan 7, 2009 | 12:17 PM
STEVE MC's Avatar
STEVE MC
I thought about that but what do you do when you have to jack up the rear? The rectangular tubing is too short to span the rear jacking points.
Old Jan 7, 2009 | 12:32 PM
Vet's Avatar
Vet
You buy two crossbeams.
Modify one for the front, and keep one stock for the rear.
Then you can lift both the front and rear at the same time, get the whole car off the ground when needed. Also handy for keeping the car level when changing fluids, etc.
http://forums.corvetteforum.com/c6-c...ml?forum_id=74
Old Jan 7, 2009 | 12:43 PM
cthusker's Avatar
cthusker
I use a Craftsman floor jack and modified my Northern adapter like this.... It works fine for both jacking the front or rear of the car. I modified my jack stands to fit the channel that the Northern adapter rests in. I never remove the floor jack to work on the car unless I absolutely have to. Most thing you don't have to remove the floor jack which simply is another safety stop in case of a problem. My idea did require welding a pin on the channel so it would exactly fit the hole on the floor jack. Not a big deal but I can change the jack back to the original configuration in about a minute...
Old Jan 7, 2009 | 12:44 PM
Motorhead-47
Exactly! I picked up two @ $29 each while browsing the Northern Tool store in Orlando...no shipping costs. One is modified for the front and the second is left "stock" with the exception of resizing the locating pin to fit.
I first used this combo when installing my insulated tunnel plate a few weeks back and felt very secure under the car when using the cross beam adapters with jackstands cradling the extensions!
POPA-VT's Avatar
POPA-VT
BINGO! we have a winner folks. This is what I did. One for the front and one for the back. Works like a charm.
Old Jan 7, 2009 | 01:01 PM
Vet's Avatar
Vet
I did after all "invent" this method. See post in FAQ from 2/2006. Royalty checks can be sent to my p.o. box, thank you.
Old Jan 7, 2009 | 01:03 PM
Vet's Avatar
Vet
Nice!
