A6 paddle shift,, Need input
Old Jan 13, 2009 | 10:30 PM
HANNY's Avatar
HANNY
Default A6 paddle shift,, Need input
looking for some input about an idea. You have seen the threads about the shifter mod, the one where you make the right paddle upshift. Its a fantastic mod (thxs for all who have come up with it and noted the work) it gives you more of an F1 type shifting (right paddle upshifts left paddle down shifts) The only problem is it makes the thumb "+" shift part kind of confusing? One upshifts and the other then downshifts.
I took mine apart again tonight and would love to get rid of the thumb part all together. Just have the paddles and thats it. Simple and more F1 like. Dont know if a vendor has this? (i know WCC has the modded ones) i may chop mine off, sand the part smooth and repaint. Your thots, (insert flame suit on here) paul
Old Jan 13, 2009 | 10:40 PM
phileaglesfan's Avatar
phileaglesfan
No flame suit needed IMO. Everyone likes it a certain way. Personally I'm use to the Corvette's OEM style. Thumbs mean upshift, fingers downshift.
Old Jan 13, 2009 | 11:10 PM
HANNY's Avatar
HANNY
good take, i wonder if I only had the paddles if a guy would loose track of which is which while cornering hard? maybe thats why they added the thumbs????
Old Jan 13, 2009 | 11:58 PM
HawaiiC6's Avatar
HawaiiC6
, as this allows me to drive with one hand at times, after using the paddles 95% of the time I am used to and appreciate the OEM shifting.
Old Jan 14, 2009 | 12:03 AM
mcwire's Avatar
mcwire
Stock configuration, seems, Ok with me. --
Old Jan 14, 2009 | 12:11 AM
Rich S.'s Avatar
Rich S.
Old Jan 14, 2009 | 12:22 AM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Stock!
Old Jan 14, 2009 | 01:27 AM
CessnaDriver's Avatar
CessnaDriver
I do not understand the logic of changing it.
You can upshift or down shift with only one hand if needed.
When steering this is very helpful.
Old Jan 14, 2009 | 07:23 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
I agree with most here, I love the stock set up, it enables you to use one hand, and either hand at that. I prefer stock over F1 style.
My 2 cents, although with inflation its probably worth $1 now.....
David
Old Jan 14, 2009 | 07:26 AM
Crikey!'s Avatar
Crikey!
Ditto for me...
Old Jan 14, 2009 | 07:32 AM
b00001's Avatar
b00001
I am with the OP, the stock set up sucks, but I would not chance cutting and sanding. I just do not use the thumbs after the mod.
Old Jan 14, 2009 | 07:48 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I think cut,sand and repaint will work. If you follow the curve of the paddle, it should look unaltered.
Old Jan 14, 2009 | 08:28 AM
FWTexas's Avatar
FWTexas
If you change it the way you describe, what would you do to downshift on a hard left turn if your left paddle was the downshift paddle? The paddle will be down between your legs. I wouldn't want to be a contortionist while driving!
Old Jan 14, 2009 | 08:38 AM
SpdWhite's Avatar
SpdWhite
Default Would prefer F1 or straight SMG shifter
I would change mine in an heartbeat.
I get confused going from a car that has F1 style to a Thumbell style.
That is one (only one) of the reasons I went with a MN6 on my last Vette. The wife, however, would like me to buy another auto.
Old Jan 14, 2009 | 10:06 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Paul I like the f1 setup and cut them up and if you want to go back to stock buy new parts they can not be expensive
Old Jan 14, 2009 | 11:56 AM
T Scott P's Avatar
T Scott P
Why would you be downshifting in the turn. Any race school/driver will tell you, all of your shifts should be done before turning in.
Old Jan 14, 2009 | 12:10 PM
danl72's Avatar
danl72
At least for now.
To A6 paddle shift,, Need input
Blue Demon Owner's Avatar
Blue Demon Owner
I thought about changing it like Hanny is doing, but then I drove in paddle mode more, and for me, the ambidextrous ability became more valuable. Just IMO.
Rick
Always Wave!!
Old Jan 14, 2009 | 12:29 PM
FWTexas's Avatar
FWTexas
True...but... upshifting out of the turn would present the same problem.
From what I have been told, this is why GM put up and down on each side of the wheel.
Old Jan 14, 2009 | 03:48 PM
HANNY's Avatar
HANNY
you could be right about that,,,that makes more sense from a stock perspective to.
I already have it set up where the paddles do what i want (right up, left downshifts) a month ago and i like it so much that way i just dont even use the thumbs. So thats really the only reason for the post. It might hurt resale but i dont really care about that,,,he** i may never sell the car. Thxs for all the input, the perspectives are always appreciated. paul
