Non-RunFlat Tire Jack Question
Old Jan 14, 2009 | 12:13 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Default Non-RunFlat Tire Jack Question
Of those of us who are currently running non runflats, has anyone purchased a portable jack they carry with them in the car, just in case? If so, which ones worked out best, if ever used? I've seen pictures of the inflatable ones which seem like a good idea and I also found a portable electric scissor-jack with a built-in electric impact which also seems like a good idea. Yes, I carry a plug kit and portable air compressor just in case already, but getting the wheel back up enough to work on it could be an issue. Thoughts?
Old Jan 14, 2009 | 01:26 AM
Snowwolfe's Avatar
Snowwolfe
About 5-6 years ago there was a gentleman on the forum who was from Germany if my memory serves me correctly. He found a scissors jack that fit the C5 perfectly and it was very small and would fit into one of the compartments in the rear.
I bought one from him for the rediciously low price of about $50 shipped. The jack was original equipment on either a Mercedes or BMW. Unfortunately when I sold my C5 the jack went with it.
Perhaps someone else can help fill in the details as to where the jacks came from and if they will work on a C6.
Old Jan 14, 2009 | 01:51 AM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Unfortunatley, the C5 had the center storage well too where you could stow that jack. Not sure there's room in the C6, other than putting it in a case or box.
Old Jan 14, 2009 | 10:30 AM
Vito.A's Avatar
Vito.A
I am going on two years without runflats. No more runflat tires for me. Just too large a compromise in handling and performance, especially the harse ride.
I have used the small air compressor a few times, but never needed a jack or spare and have not had to use the plug kit yet as I just leave the nail in it until I get to the tire shop.
For me it is usually a nail, or one time it was a small screw. The DIC will flash when the tire reaches 23psi. I can usually drive straight to Discount Tire and have it repaired.
The last nail was only a slow leak and I drove it for several days as initially I did not have time to have it repaired.
Old Jan 14, 2009 | 10:44 AM
HawaiiC6's Avatar
HawaiiC6
, I am planning of getting rid of my run-flats when I have to change tires due to wear. However I would like the comfort of knowing that I can jack the car up to do a plug should the tire go completely flat. I have yet to find a low and small jack.
So if anyone knows of one please let me know.
Old Jan 14, 2009 | 10:52 AM
Walt White Coupe's Avatar
Walt White Coupe
I probably shouldn't say it but you have tire pressure monitors so if the problem is a slow leak all you need is a compressor to get you where you have to go and you will never have to let it go completely "flat." If it does go flat so quickly that that you can't blow it back up then you have a bigger problem with the tire and a plug isn't going to fix it anyway. A jack in the rear is just something that can hit you in back of head in case of an accident.
Old Jan 14, 2009 | 11:46 AM
JoesC5's Avatar
JoesC5
I have one of those jacks. They are aluminum and they weigh ~3# and fully collapsed they are about 3inches tall. At 13 1/2 inches long they will fit in the center well of a C5 but are too long to fit in the side well of a C6. They were for a Mercedes E class sedan.
Old Jan 14, 2009 | 11:51 AM
User 81424's Avatar
User 81424
Mercedes and it was aluminum.
Old Jan 14, 2009 | 12:13 PM
dgrant3830's Avatar
dgrant3830
I found this online which looked like a cool idea.
http://www.autosportcatalog.com/inde.../5039/sc/47349
Last May, I gave away my '99 to my son which also had non runflats on it.. GY D-3's. He had a flat the other day...totally flat all the way. Large screw in the tire and per his words, loss was 5psi/minute. Way too much to move it anywhere. So that incident got me to thinking about this issue. Yes, of course for a slow leak via a nail or whatever, we usually have time enough to get to a repair facility if one can be found that's open at the particular time and the DIC keeps us informed. The airbag types, most use the car's exhaust to pump them up, but on our cars with multiple pipes, that's not going to work either.
Old Jan 14, 2009 | 12:20 PM
BriscoCounty's Avatar
BriscoCounty
The only time I can see where a runflat is more useful than a standard tire (assuming you carry a portable compressor) would be the case where you run over a board with a nail or screw sticking up. The nail/screw would not stay in the tire and just leave a hole. Most likely, a fairly fast leak that you couldn't keep the tire inflated. A runflat would help in this case.
In 31 years of driving, I have only ever had slow leak flats, nail or screw stuck in the tire, and my 07 Corvette is the first car in 15 years to get a screw stuck in it. Figures I finally get runflats, and what do you know, it goes flat on me. Although, it was a slow leak, ~6-8lbs overnight, so drove it until I could get it fixed. Just kept filling it up and a non-runflat would have worked just as well.
I'm starting to lean toward the side where runflats are a complete waste of money. But, it is nice to have them just in case - kind of like insurance.
Old Jan 14, 2009 | 12:58 PM
JoesC5's Avatar
JoesC5
I've been driving for 52 years and really have not had that many flats. Most were slow leakers like you describe, but I have had four quick flats that left me on the side of the highway. One, when I ran over a screwdriver in the pits(drag strip) in 1959. Another, when I had a blowout in 1978, Another when I ran over a screw on the Kansas Turnpike in 1966, and one where the wheelcover spun and cut the valve stem, in 1995. None of those cars had runflats and I'm sure glad I had a spare tire in the trunk. They all occurred when I was traveling away from home, not near a service station.
I won't drive a car without either runflats or a spare on board.
Old Jan 14, 2009 | 01:18 PM
harrower's Avatar
harrower
GM Includes a air pump and slime unit in their Sky and Soltice Roadsters. Non Run Flat tires and no spare.
Old Jan 14, 2009 | 01:31 PM
JoesC5's Avatar
JoesC5
And if you put that slime in your tires you are about 80% sure to destroy the TPMS sensor in the tire.
Old Jan 14, 2009 | 01:53 PM
harrower's Avatar
harrower
OK! Buy a new TPMS sensor if it is bad. Still cheaper than a tow. I would plug first if I can.
Old Jan 14, 2009 | 04:29 PM
dkrhardy's Avatar
dkrhardy
Fix-a-flat by Shell is sensor safe. Slime? I dunno. My tire guy said they do clean out tires that have been aerosol "fixed" for just a bit more money. He said that they don't like it but they do fix 'em. Shell folks told me, on the phone, that it is a soap and water clean-up.
Old Jan 14, 2009 | 05:20 PM
turmat's Avatar
turmat
You don't need the jack.
I plugged my 00 C5 with the tire on the car 'bout 4 years ago without too much trouble. Happened on the 526 bridge here in Charleston.
It is not that bad.
To Non-RunFlat Tire Jack Question
