running hot?
Old Jan 14, 2009 | 01:52 PM
bmatthe2's Avatar
bmatthe2
Default running hot?
What is a normal operating temperature for a C6 mine seems to move back and forth between 205 and 219 degrees (oil Temperature). I have seen many people say they are running more around 190 degrees. Is this a normal temp or is this hot? Keep in mind this is just normal highway and city driving.
Old Jan 14, 2009 | 02:46 PM
NY09C6's Avatar
NY09C6
Your temps are normal. Pushing it even a little in the summer will send you to 230-240.
Old Jan 14, 2009 | 03:13 PM
BrooklynC6's Avatar
BrooklynC6
aka allbottle¬hrottle
From: Brooklyn New York The DVL and the chicken sleep with the fishes....
St. Jude Donor '08
You're fine . Ive seen 260-270 at the track . No worries .
Old Jan 14, 2009 | 03:29 PM
not08crmanymore's Avatar
not08crmanymore
A little lower if it's a Z51!!
Old Jan 14, 2009 | 03:55 PM
bmatthe2's Avatar
bmatthe2
mine is a Z51
Old Jan 14, 2009 | 04:22 PM
BrooklynC6's Avatar
BrooklynC6
St. Jude Donor '08
Thats untrue , the Z51 still get plenty hot after a couple laps .
Old Jan 14, 2009 | 04:26 PM
not08crmanymore
BrooklynC6 is online now Report Post Reply With Quote
I was being facetious!
Old Jan 14, 2009 | 04:28 PM
BrooklynC6's Avatar
BrooklynC6
St. Jude Donor '08
I know , I just dont want people who dont know you are joking to assume that Z-51 equipped cars will run significantly cooler than a non-Z51 .
Old Jan 14, 2009 | 04:33 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
All is well with your temps
Old Jan 14, 2009 | 07:10 PM
Modshack's Avatar
Modshack
I think your confusing Oil with water..
Temps specified are about right for oil..
Water will run 190-200
Old Jan 14, 2009 | 09:23 PM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
LS2 or LS3 ?
Old Jan 14, 2009 | 09:25 PM
danl72's Avatar
danl72
Old Jan 14, 2009 | 09:33 PM
Brutus 08 Coupe's Avatar
Brutus 08 Coupe
You're fine. To get 190* temps, you'd need a 160* thermostat and fans set to come on at +/- 190*.
Old Jan 14, 2009 | 09:40 PM
phileaglesfan's Avatar
phileaglesfan
That is normal. I won't even hit full throttle in mine until the water temp is normal (about 195 cruising) AND the oil temp gets up to about 170. Water temp will climb somewhat when not moving due to the lack of airflow but I never seen it go above 220 or so and that is after climbing 10-12% grades in 100 degree heat. Oil temp never seems to go above 240 or so.
Old Jan 14, 2009 | 09:48 PM
mksz51's Avatar
mksz51
Let me help translate for you F55 owners:
Facetious - To try to be funny.
Hope that is helpful.
To running hot?
