Driveshaft Loop
Old Jan 19, 2009 | 12:56 PM
357's Avatar
357
Default Driveshaft Loop
Does anyone know much about a driveshaft safety loop for a C6? Do we need one at the track, if so, where do get one?
Old Jan 19, 2009 | 12:57 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
The driveshaft is enclosed inside the torque tube. No loop needed.
Old Jan 19, 2009 | 01:45 PM
C6Antwon's Avatar
C6Antwon
Old Jan 19, 2009 | 01:48 PM
johnodrake's Avatar
johnodrake
Moderator
And another view:
Old Jan 19, 2009 | 01:58 PM
bimmerborn's Avatar
bimmerborn
Is the torque transfer device inside the torque tube called drive shaft? We know drive shaft is usually between the transmission and differential. But this device is between the clutch and transmission.
Old Jan 19, 2009 | 02:43 PM
johnodrake's Avatar
johnodrake
Moderator
In the shop manual for 06C6, the 'torque tube' is referred to as the "driveline support assembly". The 'driveshaft' is referred to as the "propeller shaft".
Old Jan 19, 2009 | 03:16 PM
TANGLVR's Avatar
TANGLVR
No loop needed or any made that I know of.
If you start going crazy fast on the strip...I think sub-ten or nine seconds you'll need a clutch housing blanket to protect you from exploding clutch assemblies.
Old Jan 19, 2009 | 03:23 PM
bimmerborn's Avatar
bimmerborn
Thank you. Very good information.
Old Jan 19, 2009 | 03:27 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
"propeller shaft"????
The manual writer must have been in the Navy.
Old Jan 19, 2009 | 03:41 PM
cranky's Avatar
cranky
the only nhra legal clutch protection is a blowproof bellhousing. i do not know of anyone who makes one yet for the c6
Old Jan 19, 2009 | 04:35 PM
Fast06Z06's Avatar
Fast06Z06
What you really need is half shaft loops. They do break and can cause alot of carnage. I remember seeing one vendor that was in the process of making them. As soon as they do im game!
Old Jan 19, 2009 | 05:15 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
I really think that you need to learn more about your car before you take it to the track.
Tom
Old Jan 19, 2009 | 05:23 PM
patton's Avatar
patton
St. Jude Donor '09
Tom
To Driveshaft Loop
