C6 Electrical Problems 2005
Old Jan 21, 2009 | 09:31 PM
Vettegal2112's Avatar
Vettegal2112
5th Gear
Default C6 Electrical Problems 2005
Hi all. I am having a heck of a problem. Thought it was DBS, replaced the battery, it wasn't good. So now new battery, can't start the darn thing. I got it started, and was driving it. I pulled into my driveway to grab something from the house, left the car running (my hubby was in it)...and a ton of error messages started pouring out...low fuel, shocks inoperative, etc. I made the mistake of turning it off, and was going to restart it to see if it would clear up, and the damn thing wouldn't start again. Something very strange going on...any ideas...have you had this type of problems? The battery connection is tight, but it almost seems like something is losing communication or connection???
Old Jan 21, 2009 | 09:42 PM
St.Char's Avatar
St.Char
Sounds like this is more of a computer problem, you should take it to the dealer. Btw- you will need to re-index the windows, if you didn't do that yet.
Old Jan 21, 2009 | 09:52 PM
VET4LES's Avatar
VET4LES
I would disconnect the battery for a few minuets and see if maybe starting over will help. If not I would take it to the dealer.
Old Jan 21, 2009 | 10:58 PM
cranky's Avatar
cranky
sounds like the charging system is not working. check your volt gauge on the dash when it happens. if below 11 volts, it won't start or run the car. needs to be checked out by a competent corvette technician.
Old Jan 21, 2009 | 11:03 PM
danl72's Avatar
danl72
Old Jan 22, 2009 | 12:17 AM
cclive's Avatar
cclive
I think the charging system isn't keeping up with the needs of the car. It would explain your dead battery and low voltage would also explain the crazy messages. Charge the battery, then start the car, then check the voltage as it runs...if its below about 13.8 volts while running, then your charging system isn't doing its part
Old Jan 22, 2009 | 07:06 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
If you got a string of messages with the engine running that sure sounds like an alternator problem. Easy to check. Even AutoZone could do it IF you can keep the car running long enough to get there. Problem is it sounds like it is so bad the car will not charge enough just to keep running so you could easily end up on the side of the road. If it were me I'd call a tow truck.
P.S. I forgot the obvious. You did check under the hood and you didn't throw the belt, right?
Old Jan 22, 2009 | 07:22 AM
C8-Vette's Avatar
C8-Vette
Also start the car and check the voltage . It should be 13.5 or greater. Sure sounds like a faulty alternator.
Old Jan 22, 2009 | 05:36 PM
Vettegal2112
5th Gear
Default electrical
It does keep running after it is started....when it starts...LOL! The new battery hasn't been run down as we disconnect it if needed, like last night the interior lights wouldn't shut down.
Next time I get it started, or get in it, I'll watch the voltage...that might explain it.
We also noticed that the battery cable connection had become ever so loose, probably because of the damn cold weather....who knows.
Thanks all for your ideas and support! It did start fine today, but don't dare go somewhere and turn it off until we get this solved.
Old Jan 22, 2009 | 05:38 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
You didn't say what the voltage gauge is showing with the engine running.
Old Jan 22, 2009 | 05:42 PM
Vettegal2112
5th Gear
I didn't look, will do when I get home.....then reply... My hubby said it was low....we'll check that out.
Oh...no, haven't reindexed the windows yet...LOL
Old Jan 22, 2009 | 06:14 PM
patton's Avatar
patton
St. Jude Donor '09
if you dont have any test equiptment dont touch the car and dont take it to however replaced the battery. drop it off at the dealer
Old Jan 22, 2009 | 07:46 PM
cclive's Avatar
cclive
The reason it started was that the battery recovered a little while sitting. Charge it up, then start the car and note the running voltage.
Old Jan 26, 2009 | 06:17 PM
Vettegal2112
5th Gear
Default much better,...I hope
We revisited the battery cables. It seems that perhaps with the cold weather, they had loosened slightly, again. So the are very tight now, and no problems....so far.
The voltage is good...
Thanks for all the help, and hopefully this is the end of this...LOL!
Old Jan 31, 2009 | 12:55 AM
Vettegal2112
5th Gear
So, it isn't the end of it, fine for a few days, now problems again. I too think it is a computer problem...off to the dealer I guess...sigh.
Old Jan 31, 2009 | 01:08 AM
danl72's Avatar
danl72
Let us know how it turns out.
To C6 Electrical Problems 2005
