TPS Question
mostly!
Yes, the TPMS computer in the car can only store 4 sensor ID#'s in its memory, so each time you swap wheels you need to program the new set of sensors.
However, you don't need to go to the dealer. Since Sept '07 (with the start of the 2008 model year) the government has required that ALL new 4-wheeled vehicles less than 10,000 lbs MUST have sensors, so all tire shops know how to work with sensors and will have the tool.
The tire shop mounting up your new tires will have a tool and do the relearn procedure for you to program the new sensors.
Those of us that swap from one set of wheels to another regularly, like for track to street and back, have our own tools. There is one available for about 100 bucks if you find you need your own.
BTW, although every tire shop should have a tool to deal with sensors, and they should have a guide book that tells how to put each different vehicle in the "learn mode" and the procedure required to do the procedure on all different vehicles, it might help if YOU know the procedure to help them if they're having problems. The whole procedure only takes just longer than 1 minute, so if they're having problems you might need to make sure they know how to work with the Corvette. Below is a video that shows how to do the relearn procedure on the C6.
As you can see in the video, first put the car into the "learn mode" by pushing the bottom of the ignition button to get into the ACC mode, then simultaneously push the "lock" and "unlock" buttons on the Fob and hold them a couple seconds until you hear a honk of the horn confirming you're in the learn mode.
Then, starting at the LF tire, put the antenna of the tool on the rubber sidewall of the tire right next to the valve stem of the sensor and activate the tool to "trigger" or "excite" the sensor to send its data to the TPMS computer in the car - and you must hear a honk at each wheel (2 honks at LR) that confirms the data was sent and received correctly.
Good luck!
Bob
and it only takes about 3 minutes to reset.
This worked great when I bought new WCC Chromes with tires and monitors.
This would be a worthwhile investment for anyone planning to change wheels often, such as using a different track set.
It's been a couple of years, but I was able to find a forum member that sold the tool. A search should be able to find it.
One thing missed (and learned by me and others) is once you use the FOB to get into "learn mode", to make sure you put your FOB into your pocket!
Do not leave the FOB in the car!
Should you purposely or accidentally close the door with the FOB inside, your doors will lock on you, even bypassing your disabled
passive locking system. Its a quirk in the security programming when using the FOB for "learn mode".
This "quirk" only occurs when using the FOB to get into "learn mode" with the TPMS system.
Well.....there were a very few very early 2005 C6's that had a sensor that could be triggered by a magnet, but all C6's built from about Sept 2004 on have the sensor that requires the RF tool.
All C6's use the same sensor, GM Part# 25758220 that are made by Schrader (you can get one directly from Schrader that has their part# SB20076 - it looks exactly like the one below except it's red in color).
Below is a picture of what our C6 senors look like.
Bob
John
John
As you can see in my video, you normally put the antenna of the tool on rubber sidewall of the tire right next to the valve stem to get within a couple inches of the sensor when they are mounted in the OE manner with the valve stem sticking out of the wheel.
When the sensors are mounted with bands or brackets deep in the wheel, some owners have had success shooting through the tread to get as close as possible to the sensor.
Your tire shop should have made sure they mounted the sensors back on the same corner of the car they came off of and nothing would have needed to be done.
With exotic after market wheels, you may have to break down the bead on one side of the tire to get the tool in there close enough to the sensor to trigger it, or program the sensors to the TPMS computer in the car before they are mounted in the wheel.
Bob
