Clear Bra missing on front?
Old Jan 25, 2009 | 02:16 PM
tww's Avatar
tww
Default Clear Bra missing on front?
I was reading another post about Clear Bra's and had a couple of Q's. I did not want to hijack the OP's thread so I thought I'd start my own.
I recently bought a used '05 and it has the CB on the hood (1/2 way), front fenders, and mirrors. Funny thing though, the nose is not covered. I'm thinking maybe it got all chipped up and the original owner had it taken off...I'm not sure, but I would think the nose of the car would be the FIRST place you would want a CB...any thoughts?
Any idea what I might pay for just a "nose job"?
Thanks,
Troy
Old Jan 25, 2009 | 02:18 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Are you sure it's missing?
If a CB is properly installed you really won't see it (hint: look for the edges of it where the bumper meets the rest of the body)
Old Jan 25, 2009 | 02:22 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
You're absolutely right. The front bumper cover is an area you would want to cover before any other.
My guess is that the clear bra on the bumper cover took a beating and the old owner took it off to make the car look better. It's hard to say how much it would cost because prices vary so much from one place to the next.
Two years ago I paid about $650 or $700 for the front bumper cover, headlights, and foglights. It was a custom install, meaning they didn't use a pre-cut kit. It was well worth the money and has already saved me some heartache when I pulled in a little too close in a parking spot with a very high concrete stop last August. The Installer was able to take off a section on the bottom and replace it with no damage to the paint at all.
Old Jan 25, 2009 | 02:23 PM
Never Say Never's Avatar
Never Say Never
Most installers will replace any piece you need replaced. My installer told me if one of the pieces get damaged just bring it in for replacement.
Old Jan 25, 2009 | 02:27 PM
DA KAR's Avatar
DA KAR
Active Streak: 90 Days
Check it carefully...real good installers do not use the kits designed for specific vehicles.The installer I plan on using takes the front emblem off the vette and stretches and wraps it where u don't see any lines and then reinstalls a new emblem.He's an authorized 3m installer.
Old Jan 25, 2009 | 03:37 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
or it could be there was damage/replacement of all or part of the front bumper, the clear bra was taken off, and not replaced due to added cost.
Old Jan 25, 2009 | 05:29 PM
tww's Avatar
tww
The car has a clean bill of health according to carfax and GM. And the Bra is definitely missing. There are no edges to be found. So I think the previous owner just removed it to make it look better if it was all chipped up.
Old Jan 25, 2009 | 05:31 PM
07MontRedcp's Avatar
07MontRedcp
Originally Posted by DA KAR
Check it carefully...real good installers do not use the kits designed for specific vehicles.The installer I plan on using takes the front emblem off the vette and stretches and wraps it where u don't see any lines and then reinstalls a new emblem. He's an authorized 3m installer.
That is the kind of installer I want. I have avoided the clear bra because I have seen to many pictures were the bra actually stops a 1/2" or more short of the panel edges.
BJK
Old Jan 25, 2009 | 05:35 PM
Keith N's Avatar
Keith N
I bet you're correct. The front bumper might have needed to be repainted and the CB was not replaced.
Old Jan 25, 2009 | 09:18 PM
Texas_Venom's Avatar
Texas_Venom
BJK
A good installer will always take the film to the eddge to reduce seem lines. You can also get full hood and full fender pieces to prevent any lines across the car.
I just wrapped to Nissan GTRs (full hood and full fenders) on OAhu and you couldnt even tell there was film on the car. It was also done with precut kits to minimize the possibilty of cutting the paint. There are good installers that will be able to help you with this. If you want I can find one in your area. Just send me a PM and I will be more than happy to help out.
Old Jan 25, 2009 | 10:57 PM
bencini231's Avatar
bencini231
Old Jan 25, 2009 | 11:07 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Just FYI, in addition to getting chipped they can also scratch pretty easily. I got a spot of something on mine and used my fingernail to get it off like you might on paint. I ended up having that piece replaced because of the scratch. Also, rubbing off dried bugs without first making sure they're softened well with soap and water can scratch the bra.
Mine has been on for 3 years and in another couple years I'll probably replace it. My wife and I take lots of road trips so I wash off the bugs in spray car washes (manual, not automatic) under less than ideal circumstances. My clear bra takes a lot of abuse and isn't perfect, but has been well worth the investment. I'm sure my paint under the bra is pristine.
Old Jan 26, 2009 | 09:50 AM
hdwideglide's Avatar
hdwideglide
Mine also isn't perfect. But you are absolutely correct, it is well worth the investment.
Old Jan 26, 2009 | 11:07 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I just replaced my VentureShield after being on there for just over two years. It was worn a bit from all the driving but then got hit by a sign that was spit out form under a car in front of me on the freeway. The bra paid for itself right there and then, as it saved the bumper and hood. Had it not been for the bra, I would be having the front end fixed and painted right now. $600 for the bra is a lot cheaper than the damage and cost to repair would have been.
Old Jan 26, 2009 | 11:27 AM
jhohler's Avatar
jhohler
If it is like the clear bra I had installed on my 07 coupe when I bought it from the dealer, they did not install the bra over the nose, just the hood and mirrors which is pretty stupid. I was under the impression when I had the clear bra installed from the dealer, that the nose, out of anything, would be covered. Oh no, that was extra and of course the dealership didn't bother to tell me. You may have had the same situation.
Old Jan 26, 2009 | 01:11 PM
tww's Avatar
tww
Jeeze, that is pretty STUPID!
I'm positive the front of the car was never damaged. I am about as meticulous as one can get and I would definitely be able to find some sign of damage or a repair. No matter how good a repair job is, there is always evidence.
Troy
Old Jan 26, 2009 | 02:02 PM
trivette's Avatar
trivette
Perhaps the previous owner used a Speed Lingerie bra or other protection on the bumper and never had the 3M film on this portion? I had the 3M on my '05 bumper until this weekend when I stripped it off. It was a multiple piece install and never did look right, coupled with being black and the waviness of the cover itself. After 4 summers it was looking a bit worn also. Will probably go with another product/installer this spring, as the bumper remained perfect, so it did it's job. Others have suggested very possible scenarios for your lack of film on the bumper.
To Clear Bra missing on front?
Old Jan 26, 2009 | 03:25 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
How did you remove it and how easy (or difficult) was it?
Old Jan 26, 2009 | 04:24 PM
trivette's Avatar
trivette
Some parts of it came off easier than others. I heated it with a hair dryer which for the most part helped, then you grab an edge and pull kind of keeping it at a 90 degree angle. For some reason, parts of the adhesive would separate from the film itself leaving a fair amount of residue behind. Cleanup with 3M adhesive remover was necessary, but I actually found WD-40 was also successful and not nearly as bad for your lungs. No damage to the underlying paint, at least, as the installer did no cutting into the paint. I kept the hood/fender top protection in place, as that was less visible than that on the bumper itself. Still on the fence as to reinstalling something on the bumper, as most chips/dings I've acquired on other 'Vettes have all been above that point. I just don't want something that draws more attention to the bumper than any chips might.
Old Jan 26, 2009 | 04:37 PM
JVM225's Avatar
JVM225
St. Jude Donor '06
I believe that the 3M clear bra can be budded out just like the painted body panels. That's one of the reasons my installer gave for only using that product.
