paint scuff
Old Jan 30, 2009 | 10:59 AM
holdin5aces's Avatar
holdin5aces
Default paint scuff
Strike three, we have been hit three times in the rear. Twice, we were there and their insurance paid the tab. A $1000 plus rental car both times. Great paint matching result. This last time, not so lucky. The scuff is in the rear fascia on the side and back. When hit with a bumper it collapses and so you end up hit twice as it springs back. I'm no body guy but it doesn't look too bad. Monterey Red. How do you buff this out or at least try? If I try and it doesn't work, will it look worse yet? We have $500 comprehensive dedutible so it will cost that to have it fixed by a shop.
Old Jan 30, 2009 | 11:09 AM
mksz51's Avatar
mksz51
You can try to buff out by hand with varying grades of abrasive polish (start coarse, work to fine). May or may not be successful. Machine polishing with Porter Cable unit or equivalent is next most effective and generally what most "home" users use. It is possible to go through clear into the color coat with that but you have to try pretty hard. Real machine buffing is most effective but also has highest probability of burning through paint if you don't know what you are doing. Could you make this look worse? Absolutely. Do a search on this forum or Google for "buffing or polishing scratches" and you'll find tons of information. Pictures posted might also provide some help in determining what you can / can't do. IF the paint is cracked you're done - repaint only to fix properly. Good luck.
Old Jan 30, 2009 | 12:22 PM
Ghost 23's Avatar
Ghost 23
If you think that you would be happy with the result of buffing and polishing, you might consider taking it to your paint shop and asking them to do it. If you tell the paint shop that is all you want, they will do it. And, it will not cost you an arm and a leg for a buff and polish. The advantage is that they are experienced in working with paint. You, on the other hand, are not experienced with paint and run a much higher risk of making it worse with a result of requiring the more expensive repaint. Either way, good luck with it.
Old Jan 30, 2009 | 12:25 PM
hawkgfr's Avatar
hawkgfr
Wet sand with 2000 then buff with machine....it will look great. (if it isn't too deep)
Old Jan 30, 2009 | 01:26 PM
mksz51's Avatar
mksz51
Great advice - but dangerous in the hands of a newbie.
One other perspective - $40,000+ vehicle - worried about a $500 repair bill. That's a mismatch in my mind.
Old Jan 30, 2009 | 01:51 PM
terrymccoyc6's Avatar
terrymccoyc6
Not every one who owns a corvette is rich, and has money to burn.
I wanted a vet since I was 14.Now at 56 and saving for the least 10 years just for the down payment about $18000. I bought an 05 in 2006.Now I save to buy the mods that I like.Sorry just had to vent.
You see post every so often about not understanding why some one needs to save money by trying to do there own work.
Old Jan 30, 2009 | 02:11 PM
mksz51's Avatar
mksz51
No problem with venting - I understand what you are saying. I, for one, do ALL of my own work outside of major body work. I do this for 2 reasons - one is to save money, and two is to make sure it is done correctly and avoid some "damage" incurred by someone less careful than I am working on my vehicle.
Many Vette owners are VERY picky about their vehicles - just seems short of "abuse" to do a Mickey Mouse repair on body damage to such a nice vehicle for what I'll say is "a lousy $500". I may be totally wrong - but when someone asks about how to buff out a scuff I tend to think they have little to no experience in this area. IF you know what you are doing it can be a fairly painless process that is economical to repair. IF you don't you screw it up and it will cost you much more money to repair than if you just had the right person repair it the first time. An even better example is changing the oil. Piece of cake in my mind - but not knowing what you are doing and all kinds of badness can happen - cracked rockers, wrong filter, stripped oil pan, oil blown out of engine from not removing old filter gasket, engine seized secondary to no oil, etc. etc.
"A man's got to know his limitations"
Old Jan 30, 2009 | 02:21 PM
danl72's Avatar
danl72
To paint scuff
