recall
Old Jan 31, 2009 | 08:44 AM
randy lewis's Avatar
randy lewis
Cruising
Default recall
getting ready to pull the trigger on "o5" proably from a dealer
i have read alot about the brake line recalls. if the fix hasnt been
done will they still fix at no charge even though its being sold as a
used/certified car
Old Jan 31, 2009 | 08:57 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Boy, you're good! You do know how to research before buying. Yes, there were about 1,000 2005 Corvettes built with a bad rear brake line mounting. There was a safety recall. If, for some reason the car you are interested in wasn't fixed in 2005 (doubtful) , it would be fixed free now.
Old Jan 31, 2009 | 09:01 AM
LMB-Z's Avatar
LMB-Z
Good luck on the purchase. I love my 05. Don't know anything about the brake line recall though, sorry.
Old Jan 31, 2009 | 09:07 AM
randy lewis
Cruising
Default re
thanks for the re folks.
not going to be a daily driver. any advace you can offer that i should be on the look out for other then the normal stuff so far as the c6's
are concerned
Old Jan 31, 2009 | 09:34 AM
User 81424's Avatar
User 81424
are concerned
I bought an '05 it's been flawless, if it's a 6 speed just remember to park it in reverse.
Old Jan 31, 2009 | 09:39 AM
randy lewis
Cruising
Default re
tks maj z
keep your head down partner,
this is my retirement gift to myself of course with the generals
blessing.
looking foward to it.
Old Jan 31, 2009 | 09:46 AM
vetsvett's Avatar
vetsvett
I think it depends on whether or not it was a late or early model as to whether those issues were corrected before being sold, mine was. I would think that by now they would be. I bought my 05 in Apr 05 and all the issues had been taken care of. Even the roof.
Old Jan 31, 2009 | 09:58 AM
User 81424's Avatar
User 81424
tks maj z
Old Jan 31, 2009 | 10:24 AM
RFP's Avatar
RFP
St. Jude Donor '09
Me too... my '05 has been perfect!
Enjoy!
Old Jan 31, 2009 | 11:08 AM
VettedCandidate's Avatar
VettedCandidate
Anybody got a VIN number reference on when that was fixed at the factory?
Old Jan 31, 2009 | 11:50 AM
photoguy's Avatar
photoguy
Love mine too! 0 issues to date.
Old Jan 31, 2009 | 12:05 PM
PJRed2008's Avatar
PJRed2008
are concerned
Wasn't there something about a firmware upgrade for the nav system, or something, for the '05?
Old Jan 31, 2009 | 12:10 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
I recently bought my 05 6sp .It's been a great car!
If the one you are looking at is a 6sp, early 05s had a problem with the clutch not disengaging when shifting at high RPM. Had my clutch plate replaced at the dealer under a " goodwill warranty" and it works fine now.
If you do not plan on driving the car like it ought to be driven , you won't notice the problem.
Old Jan 31, 2009 | 12:24 PM
danl72's Avatar
danl72
Good luck with you purchase.
Old Jan 31, 2009 | 02:41 PM
NC94Vette's Avatar
NC94Vette
used/certified car
Pull the trigger. Fire away! Sounds like you have already done some good research and this forum is a GREAT resource. You can quickly scan this thread, if you haven't already: http://forums.corvetteforum.com/c6-c...questions.html
I love my 2005! As you probably already know, the build date/serial number makes a difference with several items. Mine is 132XXX, so I missed out on a lot of the earlier issues.
Enjoy and welcome.
Old Jan 31, 2009 | 07:15 PM
mmrrtt's Avatar
mmrrtt
Cruising
used/certified car
My O5 Vette Vin number is 10XXX so it has been called in a few times for recalls years ago. Heres what has been done to my Corvette, DBS flash to stop the battery from draining, NAV flash so the CD player will play MP3 incoded disc's, check of the fuel filler hose to see its not rubbing on any parts. Thats it. 32,000 miles with no problems. 28 miles per gallon using California gas, 29 miles per gallon outside CA. Good luck with your O5 Corvette.
Old Jan 31, 2009 | 10:10 PM
05_Black_Z51's Avatar
05_Black_Z51
This summer I get my 05 Z51, 6spd. It was certified, and several thousand miles later, it is all smiles.
To recall
