TPMS Question - Temperature variation
Old Feb 6, 2009 | 09:12 PM
wld35's Avatar
wld35
Default TPMS Question - Temperature variation
I live in an area of the country that experiences rather larger temperature variations in day or two, say a high of 10 degrees one day, and few days later back into the 70's, and this seems to effect the cold reading I get on the DIC, say from 27 to 33, once 34. So, I practically go nuts trying to get it to read 30 from day to day. I suppose this is normal, and that optimally, one is to adjust tire pressure when weather conditions change. I have never owned a car with TPMS before the vette, so be kind!
I searched the archives unsucessfully for a similar question, I was sure it had been posed countless times before.
Old Feb 6, 2009 | 09:44 PM
BEZ06's Avatar
BEZ06
I know what you mean - it's been down to a little below freezing here in Daytona a number of times this year, but the next day it's usually up into the high 50's or 60's. You do have quite large swings in temperature!! With the range of temps you have, you may have to adjust the cold pressures more often than most.
The common wisdom on the forum is that 10 degrees of temperature change will change the tire pressure by about 1 psi.
I don't get too worried about it - I set the pressure to 30 psi cold when the ambient temperature is the normal daytime temperature of 50 or 60. If the pressure is a couple psi low early in the morning, the tire warms up quickly when driving and gets to a good driving pressure above 30 psi, and later in the day the cold pressures will be back to 30 with the daytime rise in temp.
Make sure you're setting your pressures with a good gauge. The sensors don't start sending frequent updates to the TPMS until you drive faster than 20 mph for a few minutes, so the DIC is not something you can use to set your tire pressures.
Bob
Old Feb 6, 2009 | 10:22 PM
phileaglesfan's Avatar
phileaglesfan
Don't worry about it too much. All of your previous non-TPMS cars do it also. A TPMS car will highlight a problem you can't correct automatically.
Old Feb 6, 2009 | 10:23 PM
ShirtaDay's Avatar
ShirtaDay
Bob
Pretty much agree with everything above.
Old Feb 7, 2009 | 05:28 AM
KILR-Z51's Avatar
KILR-Z51
Just my 2 cents, I HATE TPMS!!!!!!!!!!!!!!
Old Feb 7, 2009 | 05:36 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Well...here's my 25 cents worth..... TPMS saved my butt. Let me know I had a leak in my right rear. Picked up a nail.
Old Feb 7, 2009 | 08:43 AM
tnt71's Avatar
tnt71
Default Nitrogen
If you are going to be that **** about it, try nitrogen. It does not change as much with temperature changes.
Old Feb 7, 2009 | 08:51 AM
dvilin's Avatar
dvilin
Good advice.
Bob [/QUOTE]
Old Feb 7, 2009 | 02:24 PM
phileaglesfan
The TPMS may also be off which seems to increase as you go up in altitude. Mine are 10% off to start with.
To TPMS Question - Temperature variation
