magnetic drain plug
Old Feb 9, 2009 | 02:21 PM
csun213's Avatar
csun213
Default magnetic drain plug
I have a 2006 A6, does anyone know whether I have a magnetic drain plug? If not, can someone tell me where to purchase one? Thanks
Old Feb 9, 2009 | 02:28 PM
NYC6's Avatar
NYC6
My 06 A6 did not come with one. I did buy one from my dealer about 1 1/2 years ago. I understand they are hard to find now. Hopefully someone can tell you where to get one.
Old Feb 9, 2009 | 04:12 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Not even Gene can get them anymore
Old Feb 9, 2009 | 05:05 PM
MAGDANA's Avatar
MAGDANA
MAGDANA offers the strongest magnetic drain plug out there. Called the Dimple, it outperforms any other.
Check out the website.
Joe Johnson
www.MAGDANA.com
Old Feb 9, 2009 | 05:07 PM
JoesC5's Avatar
JoesC5
I purchased two of the magnetic drain plugs for my Z06 from Ken Fichtner Chevrolet, a forum sponsor. They are aftermarket but look like the original but with the magnet installed.
Old Feb 10, 2009 | 01:56 AM
2006c6keller's Avatar
2006c6keller
Default Magnetic oil drain plug
My 06 A6 did not come with it, got it from Zip Products for about $7.
Old Feb 19, 2009 | 03:37 PM
///DarkSide\\\
Joe Johnson
www.MAGDANA.com
Order placed, according to your website that is quite the magnet
Old Feb 19, 2009 | 03:48 PM
C6~Missle's Avatar
C6~Missle
That magnet is going to cause drag on the crank shaft and slow you down.. or suck up manhole covers...
Old Feb 19, 2009 | 03:55 PM
Ounce's Avatar
Ounce
And what about those 3/4 inch steel plates they use to cover a hole! I'd hate to be driving behind that Vette.
oz
Old Feb 19, 2009 | 03:59 PM
C6CPA's Avatar
C6CPA
I bought one shortly after taking delivery of the car. Purchased at dealer for $3.25.
No manhole cover issues (yet).
Old Feb 19, 2009 | 04:49 PM
Hogvette's Avatar
Hogvette
Late Production Year 2007 (May 2007) came with the magnetic plug...
Old Feb 21, 2009 | 05:30 PM
2006c6keller
Default A new great problem!
With my magnetic oil plug installed, I had trouble getting the A6 out of "PARK" with the plug installed, it worked that well!
Old Feb 21, 2009 | 05:34 PM
VET4LES's Avatar
VET4LES
oz
Old Feb 22, 2009 | 10:00 AM
MAGDANA's Avatar
MAGDANA
OK, I've held off comment long enough
Yes, the Dimple is the strongest but we are going to launch a new "H" version for the larger thread diameters. Nearly three times as strong! The end result is oil circulation in the pan while the engine is not running.
There are other new products being introduced on March 13th. Watch for them.
Joe Johnson
www.MAGDANA.com
Old Feb 23, 2009 | 03:07 PM
Zip Corvettes's Avatar
Zip Corvettes
Platinum Supporting Vendor
We have magnetic drain plugs in stock. Our part number is OP-161 and it costs $6.50
Justin
Old Feb 23, 2009 | 04:20 PM
///DarkSide\\\
How does the oil circulate w/ the engine off?
Old Feb 23, 2009 | 08:21 PM
MAGDANA's Avatar
MAGDANA
The iron particles in the oil (micron size) are drawn to the magnet. This field attraction will pull oil with the particles. With a larger magnet the pull is greater and will cause circulation over a larger area.
I am in the process of doing a video to show the effect. Watch for the posting.
Joe Johnson
www.MAGDANA.com
Old Nov 20, 2009 | 10:30 PM
LS WON's Avatar
LS WON
Joe Johnson
www.MAGDANA.com
There are 3 pages of magnetic oil drain plugs. Which one is for a 2005 Corvette?
Old Nov 21, 2009 | 12:56 AM
SweetBlueZ51's Avatar
SweetBlueZ51
I just went to the website and it says:
  • Dimple® M12mm x 1.75 for 1996 and later Corvettes.
To magnetic drain plug
