Electrical problems
With respect to the battery going dead, if you haven't already, have your dealer do the reflash of the BCM that Chevy came up with to stop the self-discharge. Be sure to remember to always park in reverse, and disconnect any 3rd party electronics in the car. Unplug the underhood light too.
If the cause of the excessive draw is not found, then no better battery will help the ultimate problem. Because of this thread, I measured my current draw and found that after a few minutes of sitting, the car draws current that runs between 11 and 17 ma, constantly changing, as they probably have the receiver cycling, but averaging about 14ma. At this rate, the battery would be able to go for weeks and still be able to start the car.
Thus, since I got rid of the Priority Start, I have never had to worry about my battery again!
even the dealer
I'm also running a Yellow topIf the car is going to sit a while why not put a battery tender on it?
By the way, what is priority start?
even the dealer
I'm also running a Yellow topProblem is, the Priority Start is an added undesired drain on your battery!
Battery tender is OK but it should also be a desulphating one too.
Thanks for the help.
forgot to plug the tender back in when I was in the barn over Christmas time. Found that on Monday and had visions of horror. Amazing thing was, though, it started right up anyway with no jump or boost prior. So, how do we explain a well-mannered C6 that never has battery problems?--
Jay
PS. Yes, it's an A4 since my bad back doesn't handle clutches well.
