Tire pressure
Old Feb 12, 2009 | 04:52 PM
Commish's Avatar
Commish
Default Tire pressure
I currently have my tires inflated to 31psi on my 2008 C6. what is the best psi for both ride and handling?
Old Feb 12, 2009 | 05:02 PM
shopdog's Avatar
shopdog
Check the placard on the door jam. It instructs you to inflate the tires to 30 PSI cold. Do that.
Old Feb 12, 2009 | 05:05 PM
CQRT's Avatar
CQRT
Old Feb 12, 2009 | 05:10 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
I run a couple of lbs higher than the tag on the door jam tells you to. I have done that on ALL my vehicles ever since I found out...you'll get better milage and longer tire wear by doing that and it does NOT really effect your handling in normal weather. I lower the pressure for rain and cold.
Old Feb 12, 2009 | 05:29 PM
David Lasic's Avatar
David Lasic
No more than 30 psi, no less than 28 psi. Use nitrogen if possible to refill the entire tire and the pressure will remarkably keep very steady.
Old Feb 12, 2009 | 05:30 PM
RoninLS3's Avatar
RoninLS3
I run them (OEM Z51 tires) at 32 psi - so far so good!
Old Feb 12, 2009 | 08:40 PM
Tommy D's Avatar
Tommy D
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Higher tire pressure (over 30PSI) you will notice an improvement in gas mileage however the faster you go the larger effect on handling as the pressure increases. (smaller contact patch from over inflation)
When it is cold if you notice "active handling active" on the DIC because you are a bit agressive on the go pedal decrease the pressure in the rears for more grip (lower gas mileage)
But keeping the tire pressure at 30 Psi will not increase tire wear from either over or under tire inflation.
Old Feb 12, 2009 | 08:47 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
30 psi
Old Feb 12, 2009 | 08:51 PM
ufso's Avatar
ufso
Let's end this bazillioneth thread with the number 30!
To Tire pressure
