My passenger side window indexes continually. Only way to stop is to roll the window down all the way and leave it. If I roll it up as soon as it hits the top it goes down a 1/2" and then up and then down and up, over, and over, and over again.
Any thoughts on how to fix it. Following the re-indexing instructions in the manual doesn't fix it.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
You may have a defective Exterior Door Handle Switch.
You can test it by replacing it with the switch from the driver door - very easy to remove (2 phillips screws).
If it works properly, you simply replace the switch.
You can purchase the Exterior Door Handle Switch
from Gene Culley (GMPartsHouse.com) at this link:
Took the car into the dealership this morning. Props, to Criswell Chevrolet for taking me without an appointment on Saturday. They checked the car out and said the window regulator was bad and had to order a part.
