1-4 shift light
Old Feb 24, 2009 | 09:57 PM
2001 quicksilver's Avatar
2001 quicksilver
Default 1-4 shift light
C6-09 The 1-4 shift light comes on when the car is started.When the car ****s from1-4 the light on the dash does not light up. Any one have this problem and know the fix? thanks in advacne for the help
Stickboy97's Avatar
Stickboy97
buy a CAGS eliminator. The fuse works well, do a search. Southerncarparts.com sells them
Old Feb 24, 2009 | 09:59 PM
rjf965's Avatar
rjf965
no comprende your question.
the light does not come on if YOU shift from 1st to 4th, only under certain circumstances the car MAKES you shift from 1st to 4th and the light comes on.
Check your owners man. it is set out in good detail.
Old Feb 24, 2009 | 10:01 PM
dpigguy's Avatar
dpigguy
not sure what your question is. light comes on at start up to show its working. it will only come on again when you meet certain conditions like speed, throttle position, etc. check your owners manual and it will outline the conditions in which the light will illuminate and where you will only be able to shift from first to fourth. my '08 info is on page 3-38but you will need to look under instruments to find it in your OM. hope that helps.
Old Feb 24, 2009 | 10:26 PM
2001 quicksilver
The light is on when you start the car which means the light is functioning.The car will make the 1-4 shift but the dashlight does not come on when the shift is made.I know it is not the bulb must be some sensor some where.
Old Feb 24, 2009 | 10:36 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I agree with the CAGS eliminator suggestion. Put it in and you don't need to lose sleep over the light regardless
Old Feb 24, 2009 | 10:51 PM
user051728's Avatar
user051728
The light isn't for when you shift 1-4.
It comes on under certain conditions when you are in 1st forcing you to shift to 4th (locking out 2nd and 3rd).
Old Feb 24, 2009 | 11:07 PM
Vette_DD's Avatar
Vette_DD
As others have indicated, nearly all the warning lights on the dash will come on when the engine is started to let you know those warnings are working.
Here's an explanation of when the 1-4 shift light will come on and let you shift only from 1st to 4th (or 3rd). It comes from page 3-39 of the 2009 owner's manual.
One to Four Shift Light
(Manual Transmission)
When this light comes on,
the vehicle can only be
shifted from 1 (First)
to 4 (Fourth) instead of
1 (First) to 2 (Second).
The shift must be completed into 4 (Fourth) to turn off
this feature. This helps the vehicle get the best possible
fuel economy.
After shifting to 4 (Fourth), the vehicle can be
downshifted to a lower gear.
Notice: Forcing the shift lever into any gear except
4 (Fourth) when the 1 TO 4 SHIFT light comes on
may damage the transmission. Shift only from
1 (First) to 4 (Fourth) when the light comes on.
This light comes on when:
• The engine coolant temperature is higher than
169°F (76°C),
• The vehicle is going 15 to 19 mph
(24 to 31 km/h) and
• The vehicle 21 percent throttle or less.
Old Feb 25, 2009 | 07:34 AM
dvilin's Avatar
dvilin
Old Feb 25, 2009 | 09:39 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Feb 25, 2009 | 03:58 PM
Ghost 23's Avatar
Ghost 23
Search "CAGS" (Computer Assisted Gear Shifting) for at least two ways to defeat the skip-shift. (Once you figure out what it is doing, I will give long odds that you will want to defeat it.) For me, the blown Smart Glow fuse works fine.
Old Feb 25, 2009 | 04:09 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Um... I could be wrong but.....
I think he said the light comes on at start up. Ok we ALL agree that it shows that the bulb is functional and will light.
I believe he then said, "It forced him to go 1-4 BUT the light didn't come on" (or something to that effect).
That is not asking what you guys are explaining? The CAGS solenoid activated, trundled him to 4th and he says the dash light didn't light.
My question to him is "Are you sure it didn't light?" If the solenoid pushes you to 4th, the light on the dash should be lit. Briefly, even VERY briefly, but on just the same.
Elmer
Old Feb 25, 2009 | 04:29 PM
Indy is my Name's Avatar
Indy is my Name
Quicksilver...I also have this problem occasionally. Basically as Elmer stated, you know the light is working b/c it comes on at startup, however it does not function appropriately in conjunction with the actual shift from 1-4th...ie: no light is on, you go to shift from 1st to 2nd and it puts you in 4th w/ no visual warning.
Infortunately I can not provide you with a resolution or explanation *** to what is happening or why. All I can suggest, like most of the other members have suggested, the CAGS is the way to go. I have one, just have not installed it yet. It's a sure fire way to get rid of this issue.
-Chris
Old Feb 25, 2009 | 09:20 PM
2001 quicksilver
Elmer is correct. On my C5 the 1-4 lights up when it automatically shifts from first to fourth. According to manual it should work the same way on the C6. When I take it out of the winter hibernation I will look for a quick flash.
Old Mar 1, 2009 | 04:53 PM
09C6Coupe's Avatar
09C6Coupe
My light only comes on when I start the car as well but never when I am forced to shift from 1 to 4 as it should. Doesn't matter to me anyway, I tuned the CAGS out with HPTuners.
Old Mar 1, 2009 | 05:40 PM
SETc6's Avatar
SETc6
I have an extra 1-4 eliminator if someone wants it.
Old Mar 1, 2009 | 06:02 PM
ron-z51's Avatar
ron-z51
Forgive my ignorance but do all C6 with manual 6spd trans. have this feature? I've never heard of this? my 08 with Z-51 is a manual 6 spd and the car has never forced me to shift 1-4 that I know of?
Weird?
Old Mar 1, 2009 | 06:27 PM
eboggs_jkvl
Moderator emeritus
Weird?
Standard feature on most manual GM cars for quite a while now. I had it on my 98 Camaro so at LEAST the 98s had it.
Stupid EPA gimmick forced to duck the guzzler tax. I'm guessing 1994 or so for the first CAGS.
Elmer
Old Mar 1, 2009 | 07:06 PM
ron-z51's Avatar
ron-z51
Elmer
Would it be on an export car? I am in Canada and the car was purchased here. I really don't think I have that feature or I would have seen it by now? I'd check the car but it's in storage on the other side of town
To 1-4 shift light
