Splash Guards
Old Feb 27, 2009 | 08:14 AM
08Roadster's Avatar
08Roadster
Default Splash Guards
I'm thinking of putting GM splash guards on my 08 vert. Has anyone installed them? If so, can you send me a picture of what they look like - I'm concerned that they stick out too far from the body of the car. Also, was the installation as easy as the instructions make it look? thanks
Old Feb 27, 2009 | 08:25 AM
NYC6's Avatar
NYC6
Do a search, you will will find dozens of threads with more pics than you can imagine.
gota07's Avatar
gota07
Cruise-In VIII Veteran
The installation is as easy as the instructions make it look. Just make sure to use the proper size drill bit.
Here's some pics:
Old Feb 27, 2009 | 08:47 AM
JSB LS3's Avatar
JSB LS3
Here they are on mine.....they don't stick out NEARLY as far as the Apsis or even the OEM Z06 guards. I think they fit the body contour perfectly actually.
Old Feb 27, 2009 | 08:53 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
way to go
Old Feb 27, 2009 | 08:55 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'll send you pics on my vert. Is your email working?
Old Feb 27, 2009 | 09:15 AM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
I did mine yesterday. Hardest part was taking off the rear wheels. Piece of cake. 1 hour max time. I checked and rechecked before I drilled the rear holes. You need to make sure you have the correct drill bit. I used an awl to make sure the holes were centered, be sure and drill slowly, its only plastic. Looks good when you finish.
Old Feb 27, 2009 | 10:00 AM
08Roadster's Avatar
08Roadster
Thanks to everyone that emailed me...left posts and pictures. I will definitely get a pair......Jimmy
Old Feb 27, 2009 | 10:12 AM
BLACK 08's Avatar
BLACK 08
Here you go. This is my install with pics... Very easy install with outstanding results..
http://forums.corvetteforum.com/c6-c...on-w-pics.html
Old Feb 27, 2009 | 01:14 PM
1yy07vette's Avatar
1yy07vette
I let the dealer do mine , i wanted it covered under the warranty
just in case....IT took him all of 15 minutes ! IMO they do look a little more classy than some of the ones i have used . Go for it !
Old Feb 27, 2009 | 01:21 PM
miami08VETTE's Avatar
miami08VETTE
Warranty for splash guards???????????????????
Old Feb 27, 2009 | 01:29 PM
gene0809's Avatar
gene0809
NIKIDPARTS SPLASH GUARDS
Old Feb 27, 2009 | 01:44 PM
1yy07vette's Avatar
1yy07vette
Absolutely !!
danl72's Avatar
danl72
Old Feb 27, 2009 | 04:09 PM
tls630's Avatar
tls630
I put the Z06'S on mine and I am happy with them. They do stick out a little further than I would like. They are on now and going to stay. I would like to put the G.M.'S ON THE FRONT. Can't find a set just for the front, you have to buy a set.
Old Feb 27, 2009 | 04:41 PM
BLACK 08's Avatar
BLACK 08
I was a big fan of these and Nakidparts but trust me they don't even compare to the GCA ones. I took these off to put the new ones on.
Old Feb 27, 2009 | 07:01 PM
REVAK's Avatar
REVAK
Default GM splash guards
I can't post pictures, but I did inst these on my 06 vert. I think they look great, very subtle , and they actually provide some protection. The front ones are easy, the rear aren't to bad once you have the wheels off.
To Splash Guards
Old Feb 27, 2009 | 07:04 PM
Never Say Never's Avatar
Never Say Never
GM are the guards to get Look great on my 09
Old Mar 1, 2009 | 11:44 AM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I'll explain in further detail for the customer.
If you purchase a GM accessory, it is warranted for 12 months 12,000 miles.
If you purchase a GM accessory (prior to delivery) and have it installed it is now covered under the 3 year 36,000 mile warranty.
Old Mar 1, 2009 | 11:45 AM
Gene Culley
I would be happy to sell you splash guards. I am the splash guard king! lol
