Torque Spec
Old Mar 1, 2009 | 12:35 PM
vette4lyn's Avatar
vette4lyn
Default Torque Spec
I have a 2008 C6 coupe (LS3). Can some one post the torque spec for the oil pan bolts? The spec would be in Inch lbs.
Thanks,
Lyn
Old Mar 1, 2009 | 01:02 PM
Mike's LS3's Avatar
Mike's LS3
Thanks,
Lyn
Source from 2008 Service Manual:
Front two bolts M6 (facing the torque tube) 12 N-m (106 lb in).
Remaining bolts M8 to 25 N-m (18 lb ft).
Misc:
Oil cooler bolts 12 N-m (106 lb in)
Old Mar 1, 2009 | 02:57 PM
vette4lyn's Avatar
vette4lyn
Misc:
Thanks for the help. On the M8 (25 N-M), do you know the conversion to lb. in. ? You have 18 lb. ft. Or, should I be using an lb. in. torque wrench for the M6, and a lb. ft. torque wrench for the M8?
Lyn
Old Mar 1, 2009 | 03:46 PM
Rogers 07's Avatar
Rogers 07
Lyn
Multiply foot/lbs X 12 to get inch lbs. IE 1 ft/lb = 12 in/lbs. Or divide In/lbs by 12 to get ft/lbs IE: 12 in/lbs = 1 ft/lb.
Old Mar 1, 2009 | 05:56 PM
vette4lyn's Avatar
vette4lyn
Thanks for the conversion.
Lyn
To Torque Spec
