Attention: Machine Silver Owners
Old Mar 1, 2009 | 09:08 PM
jojog's Avatar
jojog
Default Attention: Machine Silver Owners
I saw this hint a while ago and tried it today, for the first time. New owners/members may never have heard that the Sharpie Silver pens do a pretty good job of matching our MS color. I had a tiny pock mark on the hood that, with just one touch of the pen, all but disappeared. The color match is perfect but, of course, the thin paint did nothing to fill the hole. It will, however, do just fine until I have enough damaged paint to warrant a better touch up job with a product that fills and can be smoothed out with special solvents (Dr.Color Chip or other like product). It is very easy to control the application and worth remembering. I have a Sharpie in the car and, after 11,000 miles on my 16 month old 2008 - this is the first time I felt the need to use it. Hope this helps someone out there.
Old Mar 1, 2009 | 09:15 PM
quicksilver436's Avatar
quicksilver436
Thanks, that is good to know.
Old Mar 1, 2009 | 09:34 PM
TRAYC7's Avatar
TRAYC7
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
Interesting....
Old Mar 1, 2009 | 09:54 PM
siffert's Avatar
siffert
Thanks...FYI...GM also sells a Machine Silver paint pen too, the exact same color. About $10.00 at your local dealer. Not to mention its thicker and can fill those tiny holes.
Old Mar 1, 2009 | 10:19 PM
PAVette's Avatar
PAVette
Thanks!
Old Mar 1, 2009 | 10:23 PM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
I also have the GM M.S. touch up paint/pen.....easy to get and also cheap $$$
Old Mar 1, 2009 | 11:55 PM
RoninLS3's Avatar
RoninLS3
Thanks for the info...next time I am in Staples I'll take a look..I have the GM one now.
Old Mar 2, 2009 | 12:28 AM
Vette_DD's Avatar
Vette_DD
Sharpie paint pens have other uses too. When I still had my MSM 05 coupe, I used a black one to fill in the letters "Corvette" on the back bumper. Sure did look good.
Old Mar 2, 2009 | 01:18 AM
Virtual Geezer's Avatar
Virtual Geezer
Thanks for the tip! My '04 is Machine Silver, too.
Old Mar 2, 2009 | 02:33 AM
chevyc6z51's Avatar
chevyc6z51
Old Mar 2, 2009 | 02:38 AM
keyplyr's Avatar
keyplyr
My next mod.
Old Mar 2, 2009 | 06:35 AM
Patman's Avatar
Patman
I also use a Sharpie marker on my black C5 to touch up little stone chips, it's definitely the better way to go over touch up paint! It's nice to know there is a match for other colors other than just black!
Old Mar 2, 2009 | 06:40 AM
Wayne88's Avatar
Wayne88
Old Mar 2, 2009 | 07:52 AM
cylon's Avatar
cylon
the pen portion of the device will usually only work once, or one day before it clogs up and u have to use the brush applicator, so wait for a few to do before you use the pen portion. At least that is what has happened to me, twice. Works well though, first time, apply the paint via the pen portion to a piece of cardboard or something.
Old Mar 2, 2009 | 07:55 AM
evoman's Avatar
evoman
thanks for the tip!!
Old Mar 2, 2009 | 08:03 PM
dkrhardy's Avatar
dkrhardy
Those darned "kits" that use a solvent type of smoother RUIN the metallic part of our MS paint. If you use one, watch out! It's great for a solid color, but metallic colors ... no way. Has ANYONE had good luck with one of the "systems" that say they will smooth out the paint chip filling procedure? Come on, fess up!
Old Mar 2, 2009 | 08:53 PM
siffert's Avatar
siffert
For really tiny chips, I dont bother with the pen. I use a toothpick as an applicator getting the paint off the brush applicator. For small ones I use a very thin haired artist brush.
To Attention: Machine Silver Owners
Old Mar 2, 2009 | 10:21 PM
Sayfoo's Avatar
Sayfoo
The above works very well.
Wait a day or so. then continue adding more coats till you are slightly higher than the surounding paint.
Then, wrap a few layers of paper towel around a flat stick--pop cycle stick--and moisten it with laquer thinner. Let it almost dry, the rub the flat side over the repair to flush up the repair.
You need the right color and for the chip to be filled in in order to really look good.
This is the same principal as the "kits" but you use $.02 worth of laquer thinner rather than their "special" solvent. Just use it fairly dry.
Old Mar 2, 2009 | 10:33 PM
danl72's Avatar
danl72
Old Mar 2, 2009 | 10:39 PM
siffert's Avatar
siffert
Wait a day or so. then continue adding more coats till you are slightly higher than the surounding paint.Then, wrap a few layers of paper towel around a flat stick--pop cycle stick--and moisten it with laquer thinner. Let it almost dry, the rub the flat side over the repair to flush up the repair. You need the right color and for the chip to be filled in in order to really look good.
Bingo! I had been using a technique kinda similar but using paint thinner on a small flat putty knife covered with tissue paper. But the thinner just seemed to make the paint darker. Never thought to use laquor thinner...thinking it was too strong but then never figured before to use it nearly dry. Thanks!
