Anxious for Spring
Old Mar 2, 2009 | 02:00 PM
Mike Green9's Avatar
Mike Green9
Default Anxious for Spring
Hi.
I know it is a bit early but I’m being optimistic about an early dry spring. I have posed this question before - what is the best way to start an LS3 after a 4 month sleep?
I have been storing cars for the winter since 1969. I never started them during the winter, always feeling this would do more harm than good. For one thing, it would be impossible to fully warm up the motor, and that's not so good for the motor and the exhaust system. Then there is the issue of carboning up the heads, etc.
When spring arrived. I used to pull the coil wire (remember those), boost the battery with another vehicle, and begin a slow cranking on/off cycle until the oil pressure gauge was up there. Then I would reconnect the coil wire, and start the car, letting it run for 10 seconds, and shut it off. I would repeat this cycle a few times, and then I was ready to rock and roll.
I was always worried that the rings would 'stick' to the cylinder walls after sitting in one place for about 4 months. Maybe I should have squirted oil in the cylinders prior to storing, and then again prior to cranking, but I never did. I never had any ring issues.
With my STS, I pull the coil fuse and crank for a few seconds, wait 10 or more seconds, and repeat this cycle a few times.
Is this necessary in today's motors? For those who do store their C6s, how do you deal with this?
Anxiously waiting to get back in the saddle again.
Thanks,
M.......
Old Mar 2, 2009 | 02:06 PM
danl72's Avatar
danl72
Soon.
Old Mar 2, 2009 | 02:33 PM
Tom_Slick's Avatar
Tom_Slick
Yes, come on Spring!!
Old Mar 2, 2009 | 03:04 PM
LarryMJones's Avatar
LarryMJones
Veteran: National Guard
St. Jude Donor '13-'14-'15-'16-'17
Default Explain why
Originally Posted by Mike Green9
Hi.
Thanks,
M.......
I do not have to winterize my Vette during winter, we occasionally have 60 degree weather here even in January. But I have a couple of boats that remain in the water year round. I always try and start them every 4 weeks or so, let them run at about 2000 rpm until the oil warms up a bit. I have been doing this since 1987 and have never noticed any ill effects. I have always heard that it keeps the seals from leaking, gets new gas into the carbs and keeps some oil film on wear surfaces. I do use Stabil gas treatment in the winter months.
It appears you could easily start and run your vehicles with the garage door open long enough to warm up the oil. Obviously we have different techniques for storage.
LJ
Old Mar 2, 2009 | 04:19 PM
photoguy's Avatar
photoguy
I had mine out today. Sunny and 20 degrees!! This is why all I do is put a trickle charger on it and cover with sheets. In 5 minutes I can be out on the road!!
Old Mar 2, 2009 | 08:23 PM
inthehunt2's Avatar
inthehunt2
Can't wait! It was in the high 40s last week and tonight is supposed to be 0! By the end of this week, high of 55.
Pic of Vette all bagged up.
Pic of what it should look like when I start to open the bag!
Old Mar 2, 2009 | 09:05 PM
candlemuse's Avatar
candlemuse
[QUOTE=inthehunt2;1569148608]
QUOTE]
Looking at the car next to the Vette , with all that junk piled up on it. That probably was a dear car one day when it was all new and had that nice new car smell , so sad , I guess that is what life is all about.
Old Mar 2, 2009 | 09:10 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
hell, my car is in the garage, without the covers, mine is READY to go
Old Mar 2, 2009 | 10:12 PM
inthehunt2's Avatar
inthehunt2
[QUOTE=candlemuse;1569148887]
Originally Posted by inthehunt2
QUOTE]
Actually it's a '69 Mustang fastback from Arizona. I am going to restore her soon. Looks sad now, but she is very sound underneath. I already have my big-block and blower for it. The entire interior is restored. Next up is the bodywork, then the engine... Don't frown yet, the 'Stang will come back to life!
Old Mar 2, 2009 | 10:38 PM
candlemuse's Avatar
candlemuse
[QUOTE=inthehunt2;1569149897]
Thanks . I was wondering what that car is. please post pics when you are done with it .
Wow (((( Resurrection )))) .
Old Mar 2, 2009 | 10:43 PM
HANNY's Avatar
HANNY
it looks like your new engine in a box on a pallet is on top of it,,,,now thats a well made car
Old Mar 2, 2009 | 10:49 PM
inthehunt2's Avatar
inthehunt2
[QUOTE=hanny;1569150326]
LOL!
When I finish her, I will definitely take pics. The interior is custom black, and the exterior will be a semi-metallic candy-apple red or hornet-yellow (I haven't decided yet).
Old Mar 2, 2009 | 10:53 PM
danl72's Avatar
danl72
Hang in there. Just around to corner.
Old Mar 3, 2009 | 08:32 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
It's a long winter
Old Mar 3, 2009 | 09:35 AM
rdm1465's Avatar
rdm1465
Back to the OP question. Just get the started. Let it run (idle) a couple of minutes. In most likelyhood you will hear some knocking from the engine. Since there is some lack of oil in the internals. The knocking will go away when the makes it way around. Then run the rpm's up to 1,000 for a moment. Then you should be good to go.
Old Mar 3, 2009 | 09:50 AM
DEO's Avatar
DEO
Spring, not soon enough!
[IMG][/IMG]
To Anxious for Spring
