C6 Running Terrible
Old Mar 3, 2009 | 01:24 AM
stoessjc's Avatar
stoessjc
Default C6 Running Terrible
I just finished installing my Z06 exhaust and now my car runs rough. Has several codes related to O2 sensor (fixed those) and a missfire code P0300. I had to disconnect the spark plugs to change the exhaust manifolds. Think I might not have a spark plug hooked up properly. I have checked all of them and they are tight. Could one or more still not be plugged in?
John
Old Mar 3, 2009 | 01:31 AM
Greenstealth's Avatar
Greenstealth
wires or plugs. This happened to me with my gto, either pull your plugs and inspect them or just replace and i would replace the wires as well
Old Mar 3, 2009 | 01:54 AM
HANNY's Avatar
HANNY
you might have hit a plug and cracked the porcelain part which causes it to missfire down the side of itself. pretty common on plugs that have solid cores (if you do) this will set missfire codes everytime. If not that then check the wires and make sure one isnt torn or ripped. Should be easy to find. If you have a scanner find which cylinder is missfiring and go right to that one. good luck ,paul
Old Mar 3, 2009 | 02:03 AM
stoessjc's Avatar
stoessjc
The code I got is P0300, engine missfire detected. I was hoping for a cylinder(s) missfire code (P0301-0308), but no luck. My code reader can't link up to CAN protocol, so had to use OnStar. I was careful not to hit a plug with the manifold, but it could have happened. I would think that a broken plug would definitely show up with a specific cylinder missfire. It also seems pretty hard not to get the connectors hooked up to the plugs.
John
Old Mar 3, 2009 | 02:06 AM
stoessjc's Avatar
stoessjc
I will try disconnecting one coil at a time with the engine running and see if one or more makes no difference in the engine operation. That should tell me where to focus my attention.
Old Mar 3, 2009 | 08:30 AM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
Old Mar 3, 2009 | 08:35 AM
danl72's Avatar
danl72
Good luck.
Old Mar 3, 2009 | 10:45 AM
stoessjc's Avatar
stoessjc
Thanks to all who responded. Never thought an exhaust swap would turn into this. Just goes to show no mod is simple and straight-forward. John
Old Mar 3, 2009 | 03:02 PM
HANNY's Avatar
HANNY
hang in there john, you will get it figured out. i like your idea of the one plug wire at a time, you might set a bunch of codes but that will be easy to clear. i still bet you have a bad plug, or wire torn. possibly did you not get one of the coils connected (not the wire side but the other side? i dont know if those had to be removed to do the manifold.
look at one of these things to be your isssue in this order, plug, wire, coil disconnected or bad, injector issue, computer issue, wiring issue. doubt you will go past the first 3 items. good luck, it happens to us all. paul
Old Mar 3, 2009 | 06:13 PM
GotVett?'s Avatar
GotVett?
You'll find it and put it behind you.
Old Mar 5, 2009 | 01:32 PM
stoessjc's Avatar
stoessjc
OK, I disconnected each coil while idling and noticed a little difference on the left bank, not much on the right bank. I also hooked a timing light up to each plug wire and observed steady light flashes from gun. Still has a missfire. If a plug was broken (porcelain cracked), that should kill that plug, right? Guess the next step is to remove each plug and visually check for damage. Can the plug wire to spark plug connection be off? The connectors are on tight - very difficult to unplug, so I think they are installed properly. I did not disconnect the coils when I replaced the exhaust manifolds. Just unplug the spark plugs.
John
Old Mar 5, 2009 | 02:48 PM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
John
Strange that it is the entire right bank. No, a cracked plug would not usually affect a timing light unless it is totally shorted. You're still getting voltage to the top of the plug where the light gets it. A crack then allows the spark to pass outside the plug rather than across the gap inside.
At this point I would try new plugs on the right side and see what happens. Have you pulled any plugs yet to check for fouling?
Old Mar 5, 2009 | 02:59 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
what year is your vette? how many miles on it? why do I ask? starting to sound like it could be one or more wires... none got kinked, right?
Old Mar 5, 2009 | 03:31 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
John
I recently had a cracked plug and the problem was that it misfired a lot more under load and only marginally while idling, making the problem harder to pinpoint.
It did however drop the idle a bit when I pulled the wire while the car was running.
Old Mar 5, 2009 | 03:57 PM
Neumonic2002's Avatar
Neumonic2002
St. Jude Donor '09-'10
That is the same way mine reacted, a broken plug seems more noticeable than a cracked wire which seems more problematic under load.
Like FortMorganAl said probably time to change the plugs on that side and go from there.
Old Mar 5, 2009 | 08:24 PM
stoessjc's Avatar
stoessjc
It is an 08 with 19,000 miles. I did not notice much change when I unplugged the right bank coils (one at a time) but could detect a slight increase in idle when I plugged each back in. Did not seem to notice the same thing on the left (drivers) bank. If I bring the engine speed up around 1300 rpms with no load, I can detect a slight miss. It is, of course, much more noticeable when driving. Also, I get a Check Traction Control warning on the dash display. Is this related to a misfire?
Can't imagine having damaged the wires. Could something happen to them unplugging from the spark plugs? They took considerable twisting and pulling to unplug.
Old Mar 5, 2009 | 08:49 PM
HANNY's Avatar
HANNY
heres waht i would do, buy 4 plugs and put them in the problem bank. If the problem goes away buy the other 4. if it doesnt go away have to figure one of the wires is bad. I would bet anything (except the vette,lol) that you have a cracked plug. good luck
To C6 Running Terrible
Old Mar 5, 2009 | 09:33 PM
dbradley's Avatar
dbradley
You can damage the wires by pulling on the wire instead of the insulator. Not hard to kill one. You can remove them all and test with an ohm meter (wiggle each end while testing) They all should read very close to the same. A broken one will show up with high resistance.
Old Mar 5, 2009 | 10:23 PM
cclive's Avatar
cclive
Very easy to damage a wire in the pulling process. Take each one and check it with ohm meter. doesn't matter what the reading is, it will be the different one that is bad. And with regard to plugs, just buy one new one and try it in each cylinder. They are easy to get to, and at 19000 miles, you are 81000 away from needing new plugs so don't buy more than the one.
Old Mar 5, 2009 | 10:37 PM
Cherokee Nation's Avatar
Cherokee Nation
